changed Master Cylinder and Bleed brakes, now car dies when I press pedal
Like it says, I changed my master cylinder and then bleed my brakes, now when I press my brake pedal the engine dies.
what the hell is going on?
I searched but Im not exactly sure what to search for so I havent found anything, Im still searching but if anyone had any insight in the mean time it'd be much appreciated
Inspect your vacuum lines, might possibly have a vacuum leak somewhere, too much engine vacuum robbed by the power brakes when hitting the pedal.
All of the vaccum lines/hoses were fine before I changed my MC. Could they have gone bad overnight? What exactly am I looking for/how do I? Theres no blatant cracks or holes I know that much....
Obviosly they were fine BEFORE you changed it if the problem persists after the change was made. Just make sure that you didnt hook up a hose to the wrong port.
Does the engine die off ONLY when you touch the brake pedal? Have you had similar problems in the past?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bjorn20 »</TD></TR><TR><TD CLASS="quote">Obviosly they were fine BEFORE you changed it if the problem persists after the change was made. Just make sure that you didnt hook up a hose to the wrong port.</TD></TR></TABLE>
Thats my point, the lines are exactly as they were before, I didnt unplug any of them, its not necessary to change the MC.
Yes the engine dies only off the brake. It idles and revs normally, but a press of the brake pedal and she dies
Well, I didn't do anything and the problem just went away. After I was on here last night I went out and checked the vac lines then gave it a try and it didn't die and hasnt yet today, so I think we're good.
Thanks for the input fellas
