68mm T/B good for my setup?
Old Feb 26, 2008 | 04:53 PM
codyellis's Avatar
Default 68mm T/B good for my setup?
Will this 68mm T/B be good for my setup?
http://www.midwestmotorsportsi...e=MWM
Motor: 12.0:1 Compression LS/VTEC
Head:
1994 B18 GSR Head
APR Head Stuts
Cometic Head Gasket
Golden Eagle Dowel Pins
Skunk2 Stage 2 Cams
KMS Valve Springs/Retainers
Sage Racing Cam Gears
Skunk2 Intake Manifold
New OEM Exhaust Valves
New OEM Valve Seals
Block:
B18A1 LS Block
New OEM .50 OS PR3 Pistons
New OEM Piston Rings
Fresh Hone
Resized Rods with APR Rod Bolts
PR4 LS Rods
Micropolished Crank
New OEM Seals and Gaskets
New ACL Bearings
New OEM ITR Oil Pump
Balanced Bottom End
Trans:
1994 GSR Transmission
Stage 2 Exedy Clutch
Tune:
P72 Tuned with Crome
Misc:
RC 310cc Injectors
Edelbrock Oil Sandwich
JDM ITR Header
2.5 Custom exhaust
Apexi WS2 Muffler
Old Feb 26, 2008 | 08:07 PM
jeffy's Avatar
Default Re: 68mm T/B good for my setup? (codyellis)
what is your goal with the car? if its a straight race car then yeah that TB would be ok, but for a DD/race car id go more with a 65 or 64. by the way i think your compression is prob a little closer to 11.6 or so.
Old Feb 28, 2008 | 02:02 AM
codyellis's Avatar
Default Re: 68mm T/B good for my setup? (jeffy)
Anyone else have any other input?
ryguy2588
Aug 29, 2012 12:58 PM
ShawnR
Mid-Atlantic (Sales)
12
Dec 19, 2008 07:33 AM
ShawnR
Dec 16, 2008 08:58 AM
00b18b
47
Jun 10, 2008 06:19 AM
