Tie rod scraping wheel on full lock.
Just as the title says. On full lock each way the outer tie rod scrapes against the edge of the wheel.
A little background. I just replaced the rack end bushing, along with the inner and outer tie rods. All the parts were identical in size to the ones being replaced. I don't think it was doing this before the alignment, but I have no way to be sure. I am wondering if I need to do a little more adjustment on the steering gearbox?
Stock 88 Si
260K miles
H&R springs
Integra Swirl rims (15X7??)
WTF?
Modified by schueytenten at 4:37 AM 2/27/2008
Stock 88 Si
260K miles
H&R springs
WTF?
Which way do the curved ends go? I only ask because today I found a radially groove being dug into my rim and I have no idea where it came from and this fits the diagnosis.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman »</TD></TR><TR><TD CLASS="quote">I'm surprised you can even put them on wrong. </TD></TR></TABLE>If there's a will, there's a way. I'm going to run downstairs and take a picture of mine and if you could, let me know if you see anything amiss.
Well, I see a big L on it, so I'm assuming I did it correct
Modified by dr_latino999 at 9:22 PM 2/26/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">Im pretty sure you swapped left and right tie rods, they have a curve to them and you put them on the wrong sides.
That is just what I DIDN'T want to hear.
This is how I feel now.
I don't know how the hell I did that? Just when I thought I was able to function on only 6 beers. I think Tecate pwn3d me that day.
Modified by schueytenten at 10:15 PM 2/26/2008
Just got a chance to fix the problem. Although I deserve the hammer to the head, one was marked L, and the other was marked L1. So I put the L1 on the left and didn't even look at the other one as I screwed it on. Leave it to autozone to screw up tie rods too.
All better now. Thanks guys.
