90 Accord CEL code 43
Old Feb 26, 2008 | 01:51 PM
tonyguns's Avatar
Default 90 Accord CEL code 43
Here's what's new:
Fuel Filter
Cleaned injectors
200K but engine is freshly rebuilt, and the CEl was on before the build.
What could be causing the code 43? (fuel system failure code)
Thanks-
Modified by tonyguns at 5:15 PM 2/26/2008
Old Feb 26, 2008 | 05:39 PM
hondadude's Avatar
Default Re: 90 Accord CEL code 43 (tonyguns)
Oh no, please no, not the DREADED code 43
First thing you need to know is the code meaning was screwed up in translation, from japaneese, to Hondaeese.
What it really means is that the O2 sensor is seeing unburned oxides, and really doesn't have squat diddley to do with the fuel supply system.
It could be a lazy O2 sensor, ruptured diaphram in the FPR, weak spark, overly tight intake valve.
Just treat your diagnostic approach as if you are looking for a reason the engine is running in an overly rich condition.
Old Feb 27, 2008 | 05:23 AM
tonyguns's Avatar
Default Re: 90 Accord CEL code 43 (hondadude)
Thanks, I am getting an O2 sensor code too, so I'll start there.
Old Mar 6, 2008 | 08:36 AM
tonyguns's Avatar
For those who have seen this problem, I replaced the O2 sensor, and the code 43 cleared. I was also getting a code 1. Both are cleared.
Old Apr 21, 2008 | 03:33 PM
92jdmhatch's Avatar
bump
jrwhites
Jul 15, 2008 03:37 PM
JDMhondalude22
Nov 8, 2006 04:55 AM
b18_crx
Oct 27, 2005 05:19 AM
DarkBB4
Aug 27, 2005 09:31 AM
Accord_Kid
May 20, 2005 06:28 AM
