B18 Wiring harness question
i have a 91 crx with b18b1, what wire harness do i need for this,....???????
and i have predy much everything. and what else do i need for this. just want to know to see if i have the right things.
Modified by ikaika3269 at 5:21 PM 2/26/2008
well the crx i got had a bad harness couldnt find the problem with it. i used my old harness on it, it was off a 89 hatchback and it worked. but i no longer have the harness cuz i sold it. so i have no harness at all. i was woundering if a si crx harness would work. i have no idea what harness would work. so i was just woundering what harness would i use to plug n play. and what ever else i need. i have the all the things i need for the swap, i just need for someone to list what i need for the swap, need to make shure i bought all the right things. thanks bro.
oh yeah i got a b16 tranny, i think ima get rid of the b16 tran for the stock ls tranny. i dont know yet. i just want to see how the car is going to run. if it gunna run good as i hope ima turbo the car. hope fully 14 flat. ill be happy then, then go turbo. we will see. the motor came out the old hatch and it ran around 14 something. but tires spun bad. so i want to see how the crx is going to go. ill post of pic of da car in a few
is it cable or hydro. how good is it u might just want to stay with it o and good luck geting that turbo to fit i would just go all moter and
ha it tricky to post pics go to tinypic.com and u can upload them that way it free and u can resize them to 15/17in monitors they comes in the default and that way to big make sure to resize them.
damn it need som love well i would defenetly clean it up way befor doing any thing mager my freinds crx had a b16 and he just got it runing and hes having all sorts of problems wish u the best of luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ikaika3269 »</TD></TR><TR><TD CLASS="quote">well the crx i got had a bad harness couldnt find the problem with it. i used my old harness on it, it was off a 89 hatchback and it worked. but i no longer have the harness cuz i sold it. so i have no harness at all. i was woundering if a si crx harness would work. i have no idea what harness would work. so i was just woundering what harness would i use to plug n play. and what ever else i need. i have the all the things i need for the swap, i just need for someone to list what i need for the swap, need to make shure i bought all the right things. thanks bro.</TD></TR></TABLE>
You need to use the harness for your chassis model..If you don't have an SI, the si harness will NOT work. Just get the harness for your car!
exist12
Oct 26, 2007 08:19 AM
