My h22a - Something's missing?
I just got my h22a in from tigerjapanese, and it's missing something on the end of the fuel rail. There is a banjo-style bolt there, and an imprint on the fuel rail for what I would guess is a fuel hard line.
I looked at my h23 and noticed it's not the same, there's a bolt there but it's not a banjo bolt and there's no line impression on the rail like on my h22a.
Again...far right side of the fuel rail on top of it, banjo-bolt is there but what goes between the bolt and fuel rail is not there. What the hell is supposed to be there?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHK4TIX »</TD></TR><TR><TD CLASS="quote">if your dropping it into your prelude, just use the fuel rail off the h23 and dont worry about that little piece.</TD></TR></TABLE>
Plus 1.
The JDm fuel rail is reversed. You couldnt use it anyway unless you did a fab job on the fuel line.
Plus 1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker »</TD></TR><TR><TD CLASS="quote">
Plus 1.
The JDm fuel rail is reversed. You couldnt use it anyway unless you did a fab job on the fuel line.</TD></TR></TABLE>
^^ x2. usdm h22 and h23 are the same fuel rail, just us one of those instead.
Plus 1.
that is why you don't buy from tigerjapanese------engine ends up missing pieces....
mine was missing vtec solenoid and pressure switch----plus valve cover was cracked....and they shipped to someone else and expected me to go pick it up...no customer service at all....
but yeah---use ur h23 fuel rail----did that on mine...plus h23 ps bracket---
Make sure you add that to the officalwhere did you get your motor thread<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlyingDaggers »</TD></TR><TR><TD CLASS="quote">that is why you don't buy from tigerjapanese------engine ends up missing pieces....
but yeah---use ur h23 fuel rail----did that on mine...plus h23 ps bracket---</TD></TR></TABLE>
