B16a1 swap help.
Old Feb 25, 2008 | 08:32 PM
MugenMaster's Avatar
Default B16a1 swap help.
I've got a 1994 civic coupe and i took the b16a1 out of my swaped 1990 integra to put in my car. I have gotten the right mounts and i ordered a OBD1 to OBd0 distributor adapter and OBd1 to Obd0 engine harness. I also bought OBD1 injectors and an o2 sensor. I also bought the hasport hydro to cable mount so i can use my calbe clutch in the car. But my concern is do i need to buy an OBD1 ecu or is the obd1 to obd0 ecu harness made so it will plug into my Obd0 ecu??? HELP ME.
(the name isnt serious by the way)
Old Feb 25, 2008 | 08:38 PM
jasony0630's Avatar
76.26.106.124
there are b16a1's???
i didnt know that....
Old Feb 25, 2008 | 08:41 PM
Why wouldn't there be a1 if theres an a3??
Old Feb 25, 2008 | 09:30 PM
palisoc05's Avatar
Default Re: (MugenMaster)
well, u said that u ordered and obd1 to obd0 engine harness....im assuming that you mean a conversion harness so that you can run an obd0 ecu with your obd1 vehicle. it probably would be a plug and play...but what im doing is i converted my ef to obd1 cause i swapped a d16z6 but now im swapping a b16a but im keeping it obd1 and using the p28 ecu. btw i dont think that there is a b16a1, first gen b16's were just b16a...i think people throw the 1 in there to indicate that its a first gen but its stamped b16a.
Old Feb 25, 2008 | 09:33 PM
USDMCIVICHATCH's Avatar
Default Re: (palisoc05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by palisoc05 &raquo;</TD></TR><TR><TD CLASS="quote">well, u said that u ordered and obd1 to obd0 engine harness....im assuming that you mean a conversion harness so that you can run an obd0 ecu with your obd1 vehicle. it probably would be a plug and play...but what im doing is i converted my ef to obd1 cause i swapped a d16z6 but now im swapping a b16a but im keeping it obd1 and using the p28 ecu. btw i dont think that there is a b16a1, first gen b16's were just b16a...i think people throw the 1 in there to indicate that its a first gen but its stamped b16a.</TD></TR></TABLE>
CORRECT
ricardo13d
11
Dec 8, 2011 06:55 PM
VTEC_Honda
Jun 1, 2011 03:54 PM
bayron
May 14, 2009 05:39 PM
G2integra217
May 8, 2005 11:39 PM
tRex99
Sep 5, 2004 05:28 PM
