Fuel press. reg. through purge valve. Cause leaning???
Old Feb 25, 2008 | 08:28 PM
slow hatch's Avatar
Default Fuel press. reg. through purge valve. Cause leaning???
I thought that the fuel pressure regulator's vacuum source was suppose to be direct. Mine goes through a purge valve, before going into the IM. I was having problems leaning out about 6k on the dyno, and was told this was my stock fuel pump. Could this have been the problem?? Thanks
Old Feb 25, 2008 | 09:31 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
why not get an aftermarket fuel pump? 90 dollars and you find out if its leaing out because of the pump, sounds good to me. what FPR are you using?
Old Feb 25, 2008 | 09:58 PM
slow hatch's Avatar
Default Re: (jdm_dc_fan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_dc_fan &raquo;</TD></TR><TR><TD CLASS="quote">why not get an aftermarket fuel pump? 90 dollars and you find out if its leaing out because of the pump, sounds good to me. what FPR are you using? </TD></TR></TABLE>
Its stock right now. I probably will just go ahead and get a walboro
vietxdragon
Oct 12, 2007 09:32 AM
beef-cake
Feb 26, 2007 08:16 PM
champLSinteg
Sep 20, 2006 04:39 PM
JLHDOHC
Apr 21, 2006 08:46 PM
crxvtecred
Oct 30, 2005 12:45 PM
