CRX Thermosensor Question...
Old Feb 25, 2008 | 08:16 PM
XspeedSi02's Avatar
Default CRX Thermosensor Question...
Just finished up replacing my clutch on stock motor, but... as I was putting the tranny back on a couple wires broke loose from a plug that goes into the motor right under the distributor. From pictures that I have looked at online I'm thinking it was the Thermosensor plug which I think controls the fan. Correct me if I'm wrong but if anyone has a picture of this area and can post it up showing me the Thermosensor plug. If this is the thermosensor can just the plug be replaced or do I need to find the whole part of that wiring harness. Does a parts store like Advance Auto/Auto Zone carry it or only Honda dealer. Any help would be greatly appreciated.
Old Feb 25, 2008 | 11:24 PM
jamison1486's Avatar
Default Re: CRX Thermosensor Question... (XspeedSi02)
i dont know about a d-series but on a b-series look under the vtec solenoid and its the first plug you'll see in the block. hope that helps.
Old Feb 25, 2008 | 11:43 PM
slowcivic2k's Avatar
Fan switch is on the thermostat housing, the ones on the head are temperature sensors, one for the cluster, and the other for the ECU.
EDIT: PM and figured out he had an 1988 CRX. (browsing too many forums at once) Correct location is near the oil filter on the back of the block, large two pin connector.
Modified by slowcivic2k at 3:08 AM 2/26/2008
Old Feb 26, 2008 | 06:38 AM
alscrx's Avatar
Default Re: CRX Thermosensor Question... (slowcivic2k)
If its the black sensor with the gold hex head and 2 prongs then its the temp sensor.
Old Feb 26, 2008 | 04:32 PM
XspeedSi02's Avatar
I have attached a picture of where the plug broke loose from the wires. If someone could let me know for sure what this plug is so that I can request one in the WTB section. My guess from research is the Thermosensor plug for the ECU which controls the fan.
Old Feb 26, 2008 | 04:42 PM
XspeedSi02's Avatar
^^ BUMP ^^
Modified by XspeedSi02 at 2:26 AM 2/27/2008
Old Feb 26, 2008 | 07:22 PM
Crx Jimmy's Avatar
that is for the ecu to see the water temp, the little one next to it is for the gauge cluster, the ecu does not control the fan it has a fan switch on the back of the block for that
Old Feb 26, 2008 | 10:10 PM
DailyDriverCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XspeedSi02 &raquo;</TD></TR><TR><TD CLASS="quote">^^ Added Picture Above ^^</TD></TR></TABLE>
You seriously made a post to say that you posted a pic in the post right above it. Priceless.
Old Feb 26, 2008 | 10:25 PM
XspeedSi02's Avatar
Default Re: CRX Thermosensor Question... (DailyDriverCivic)
Yeah so it would bump it up. I'll reword it for you.
Old Feb 27, 2008 | 05:36 AM
alscrx's Avatar
Default Re: CRX Thermosensor Question... (alscrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx &raquo;</TD></TR><TR><TD CLASS="quote">If its the black sensor with the gold hex head and 2 prongs then its the temp sensor. </TD></TR></TABLE>
I posted this before your pics....its a temp sensor
blinger
Apr 25, 2007 02:00 PM
mondo375
Jul 8, 2006 10:14 AM
Scream'nSol
Oct 5, 2002 03:32 PM
andykatz1
Mar 13, 2002 01:13 PM
