im swaping my b18 in my eg from my ef. what parts can i still use?
Old Feb 25, 2008 | 08:14 PM
tealsvteceg's Avatar
Default im swaping my b18 in my eg from my ef. what parts can i still use?
im swaping my b18 out of my ef into my eg. it had avid linkage in it and integra hubs and axles. im still gonna use my cable tranny in it too. so what parts can i still use off the ef for my eg?
Old Feb 25, 2008 | 08:54 PM
Dasfinc's Avatar
Default Re: im swaping my b18 in my eg from my ef. what parts can i still use? (tealsvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tealsvteceg &raquo;</TD></TR><TR><TD CLASS="quote">im swaping my b18 out of my ef into my eg. it had avid linkage in it and integra hubs and axles. im still gonna use my cable tranny in it too. so what parts can i still use off the ef for my eg?</TD></TR></TABLE>
cable tranny no worky in EG unless you get a conversion kit.
Mounts and linkage should all still be the same IIRC.
Old Feb 25, 2008 | 09:16 PM
USDMCIVICHATCH's Avatar
Default Re: im swaping my b18 in my eg from my ef. what parts can i still use? (Dasfinc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasfinc &raquo;</TD></TR><TR><TD CLASS="quote">
Mounts and linkage should all still be the same IIRC.</TD></TR></TABLE>
The mounts are not even close to being the same or the shift linkage or the hubs, however you can use the axles
Old Feb 26, 2008 | 07:54 PM
Default Re: im swaping my b18 in my eg from my ef. what parts can i still use? (USDMCIVICHATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMCIVICHATCH &raquo;</TD></TR><TR><TD CLASS="quote">
The mounts are not even close to being the same or the shift linkage or the hubs, however you can use the axles</TD></TR></TABLE>
i was told u cant use the integra axles in the eg? but i thought u could use the avid linkage in the eg?
Old Feb 26, 2008 | 11:49 PM
yes you can use the 90-93 teg axles!!!!!!!! but you need the 90-93 mid shaft also, the Avid Ef linkage is way too short, you need 94-01 teg linkage for the Eg
Old Feb 27, 2008 | 08:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMCIVICHATCH &raquo;</TD></TR><TR><TD CLASS="quote">yes you can use the 90-93 teg axles!!!!!!!! but you need the 90-93 mid shaft also, the Avid Ef linkage is way too short, you need 94-01 teg linkage for the Eg</TD></TR></TABLE>
ok yea i do have a mid shaft. what about that t-bracket that mounts on the tranny and goes on the back motor mount. can i keep that?
Old Feb 27, 2008 | 09:54 PM
no, you need a 94-01 Integra T bracket
Old Mar 2, 2008 | 06:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMCIVICHATCH &raquo;</TD></TR><TR><TD CLASS="quote">no, you need a 94-01 Integra T bracket</TD></TR></TABLE>
im going obd1 and i want to no if i can use the altenator off my d-series on the b18
Bluegixxer1k
Jul 1, 2011 07:36 PM
iheartmycvc
Sep 15, 2008 12:43 PM
D16SohcVtec
14
Jan 15, 2008 04:49 AM
Jonnyr4c
41
Nov 25, 2004 03:48 PM
