STEERING WHEEL PROBLEM
Hey guys, well i was having a little issue w/ my steering wheel placed on crookedly.
Well, i fixed that problem and i'm finally driving like a normal person now, lol.
Anyways, i ran into a couple more problems, i'm just wondering you guys have heard of or can help me out..
I reassembled my steering wheel like 5 times. it's stock btw.
i connected the 2 horn components and the yellow airbag plug the same way i took it off. and the same i did before i switched up steering wheels.
When i re connected all my necessary plugs, the SRS light turned on. so i re did the assembly with my negative disconnected, and it still is there.
ALSO, my turn signals don't work properly. They don't turn off after i turn the steering wheel.
SOOOO, i was just wondering if you have any trouble shooting ideas i can probably try. cause i'm all out of ideas, and i don't want to take it to a shop and have then look at it for like $75. Thanks a lot guys!!
just as Matt said if you unplug any SRS item while the battery is plugged in you triggered the SRS light ...
use this to help reset...
http://www.civicforums.com/for....html
instead of using thee tool just use two speaker wires
Ur 2 Slow 4 J
Nov 1, 2015 02:25 PM
