Suspension & Brakes Theory, alignment, spring rates....
eg with dcr suspension
Old Feb 25, 2008 | 07:38 PM
meric0786's Avatar
Default eg with dcr suspension
ok i need to know if i should go with coil overs or a strut setup its in my eg hatch will be auto x the car drag race here and their but more auto crossingusing skunk2 itr lca's with skunk2 uppers front and rear asr brace with asr sway bar and jdm typr front
Old Feb 26, 2008 | 07:51 AM
Relic1's Avatar
the adjustability of coilovers is always a better option (if you can get the car balanced), but it really depends on what the normal usage of the car is and what you like for ride quality.
Stiffer is usually better on the track and strip, but not so on the street.
IMO, pick up a set of good coilovers with a good track setup, then pick up a set of drag springs for them. Swap when needed.
Old Feb 27, 2008 | 01:57 PM
meric0786's Avatar
Default Re: eg with dcr suspension (meric0786)
ok what is recommended as an upgrade for a front swaybar
Old Feb 27, 2008 | 03:54 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meric0786 &raquo;</TD></TR><TR><TD CLASS="quote">ok what is recommended as an upgrade for a front swaybar</TD></TR></TABLE>
Depending on the car and spring rates, either remove it completely or "upgrade" to a smaller bar.
Old Feb 28, 2008 | 01:49 PM
meric0786's Avatar
Default Re: eg with dcr suspension (TunerN00b)
why would i remove it or go to a smaller bar i am thinking of omni coilovers 12k front and 10k rear on my eg hatch
Old Feb 28, 2008 | 02:41 PM
Relic1's Avatar
removing the front bar, or "upgrading" to a smaller bar means more oversteer.
Less bar in the front or more bar in the rear = more oversteer or less understeer.
more bar in the front or less bar in the rear = more understeer or less oversteer.
upgrade is a bad term to use for this type of thing. One persons upgrade is a downgrade to another.
you have to tune the suspension to your driving style and how you are going to use the car.
Old Feb 28, 2008 | 06:50 PM
meric0786's Avatar
Default Re: (Relic1)
want to auto cross and scca style
Faultless18
Suspension & Brakes
10
Nov 19, 2008 07:54 PM
evoix4me
Suspension & Brakes
Feb 5, 2007 05:49 PM
93dabeast
Feb 2, 2007 07:37 AM
94hatchvx
Suspension & Brakes
Feb 23, 2006 04:59 PM
TorganFM
Nov 15, 2003 01:17 PM
