questions about b20's
Old Feb 25, 2008 | 06:39 PM
hondahead87120's Avatar
Default questions about b20's
I have a question bout these 2 cranks, I was wondering if they are the same, if not which is better, i need to know because i just bought a b20b bare block and im trying to put it back together, and piston rods are the b18a rods the same as the stock b20, NEED INFO ON THIS ASAP
Old Feb 25, 2008 | 10:43 PM
lsvtec300's Avatar
Default Re: questions about b20's (hondahead87120)
you cant use the pistons cause the b18 is an 81mm bore while the b20 is a 84mm bore. sroke is the same on both which is 89mm
Modified by lsvtec300 at 5:45 PM 2/26/2008
Old Feb 26, 2008 | 04:32 AM
chad's Avatar
Moderator
Default Re: questions about b20's (lsvtec300)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec300 &raquo;</TD></TR><TR><TD CLASS="quote">you cant cause the b18 is an 81mm bore while the b20 is a 84mm bore. sroke is the same on both whick is 89mm</TD></TR></TABLE>
you can use an LS crank in a b20.....you can use the RODS of an LS in a b20, you can not use the pistons in the b20
b20=84mm
b18a/8=81mm
you could use the 81 mm pistons if you resleeved the b20 and went to a smaller bore but that would be stOOpid.
b20b/z=b18a/b cranks an rods
Old Feb 26, 2008 | 12:56 PM
95 integra's Avatar
Default Re: questions about b20's (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">
b20=84mm
b18a/8=81mm
b20b/z=b18a/b cranks an rods</TD></TR></TABLE>
I'd listen to the guy with 10,000 posts.
Old Feb 26, 2008 | 01:20 PM
lilintegra25's Avatar
hey i have b20 pistons and rods.. 84mm ...60 bucks shipped
stock
Jeremy Hoffmann
Aug 25, 2018 04:22 AM
boblaw
Feb 24, 2008 08:49 AM
theSQad
19
Feb 11, 2004 12:12 PM
GRIMEY.STREET.RACER
Jul 29, 2002 09:28 PM
GRIMEY.STREET.RACER
Jul 28, 2002 03:30 AM
