burning out fuel pump relays
Old Feb 25, 2008 | 06:11 PM
Only1cam's Avatar
Default burning out fuel pump relays
Alright, so my 89 si hatch has had a d16y8 swap in it for over 2 years. After it has been sitting for about 5-6 months, i had a new downpipe put on it and my engine builder noticed the fuel pump relay was bad, due to no fuel getting to the motor and the pump being good. After switching it out the first time, worked great. Car sat for another 2 days, and that new relay burnt out. ANOTHER relay in, and a week later (this past saturday) another relay was burnt out. I had to get the car home to tampa from cocoa beach so I went ahead and put in another relay and disconnect it everytime I shut the car off. So 3 fuel pump relays in less than 2 weeks, and this is the first time its ever happened.
Could it be the stock pump finally giving up, and causing the burn outs? Or should I go straight at the wiring to the relay??
Any help would be appreciated thanks!
Old Feb 25, 2008 | 06:44 PM
JOE BD-0's Avatar
Default Re: burning out fuel pump relays (Only1cam)
Are these brand new units that you are using, and burning out?
Old Feb 25, 2008 | 07:48 PM
Only1cam's Avatar
Default Re: burning out fuel pump relays (JOE BD-0)
yes sir 2 brand new ones and one used. Picked up the 3rd one today from honda parts in the plastic wrapper
Old Feb 25, 2008 | 08:02 PM
alscrx's Avatar
You should grap a diagram and start checking your wiring!
Could be a ground to short somewhere
Old Feb 26, 2008 | 07:16 AM
Only1cam's Avatar
Default Re: burning out fuel pump relays (alscrx)
I realize that it most likely is the wiring, so where could I get ahold of such a wiring diagram?
and is it still possible that maybe a mechanical failure is causing this as well?
Old Feb 26, 2008 | 07:36 AM
vitaminb18a1's Avatar
My CRX was burning up main relays as well it was also making a crazy buzzing noise.. turned out the relay wasnt grounding well. The wiring diagram in the haynes repair manuals are pretty exact you can pick them up at pep boys too.
got_no_sol
Mar 31, 2017 06:32 PM
carlos8
Oct 27, 2013 01:26 PM
datonefoo1
Feb 8, 2008 12:29 PM
