LS Crank in GSR Block???
Old Feb 25, 2008 | 05:46 PM
BIG T's Avatar
Default LS Crank in GSR Block???
let me first say that i have searched did ot really find the answer i was looking for.
ok so got a simple question here
if i put an LS crank in a stock GSR (B18C1) Block
will the compression raise or drop??
What would it then be as well??
Old Feb 25, 2008 | 06:08 PM
Combustion Contraption's Avatar
Do you understand how an internal combustion engine works?
Old Feb 25, 2008 | 06:12 PM
BIG T's Avatar
Default Re: (Combustion Contraption)
a simple answer would suffice here??
Old Feb 25, 2008 | 06:13 PM
Give a man a fish...
Old Feb 25, 2008 | 06:17 PM
b19coupe's Avatar
Default Re: LS Crank in GSR Block??? (BIG T)
The short answer is that an LS crank will raise compression.
Do your homework and find a compression calculator.
Old Feb 25, 2008 | 06:18 PM
IntegraType-R's Avatar
longer stroke, puts the piston higher then a gsr crank yes? increasing cyl pressure, therefore increase compression.
98vtec's Avatar
moderator emeritus
adding stroke by itself reduces chamber volume.
Old Feb 25, 2008 | 06:20 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (BIG T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIG T &raquo;</TD></TR><TR><TD CLASS="quote">a simple answer would suffice here??
Seriously...it is unbelievably easy to find the information you want, not only on here, but messing with the online compression calculators as well. A basic understanding of the internal combustion engine will also give you your answer. People aren't going to hand you answers that are so easily found with a little effort...
Default Re: LS Crank in GSR Block??? (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">The short answer is that an LS crank will raise compression.
Do your homework and find a compression calculator.</TD></TR></TABLE>
Why do you have to be such a spoil sport? Its not like this guy was asking "should i make sure my intake cam gear is tightened properly before Todd dyno's it?"
Old Feb 25, 2008 | 06:25 PM
b19coupe's Avatar
Default Re: (IntegraType-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R &raquo;</TD></TR><TR><TD CLASS="quote">longer stroke, puts the piston higher then a gsr crank yes? </TD></TR></TABLE>
If you use GSR rods, yes. Then your pistons may also make contact with your cylinder head. Compression calculations would then become moot. When using an LS crank it is recommended that you use LS rods. At that point the pistons should be at about the same height as with a GSR crank and rods.
And always tighten your damn cam gear(Steve) before Todd dyno's your motor so that he does not have a heart attack!
Old Feb 25, 2008 | 07:58 PM
BIG T's Avatar
well i was under the impression that it would raise the compression like you just stated i just was not sure if my info upon where i get the length of the rod and stroke was correct.
Old Feb 25, 2008 | 09:33 PM
all-mtr-teg's Avatar
Most accurate compression calculator site I can think of
http://www.clubcivicquebec.com...f.php
Old Feb 27, 2008 | 10:16 AM
Default Re: (b19coupe)
i was answering his question I know which rods to use , he asked about compression tho.. of course it'll raise compression
Old Mar 2, 2008 | 05:36 PM
9t4fodo's Avatar
Here is some good info on the subject.
https://honda-tech.com/zerothread?id=1837872
Old Mar 3, 2008 | 06:46 AM
Chris Tune's Avatar
Default Re: (9t4fodo)
people tend to forget the why it raises comp...
if u have 2 bores at 80mm and one stroke to 95mm and one to 75mm if both tdc at .45 from the head using a 00 cc piston... which will have more comp and why?
Modified by Chris Tune at 8:00 AM 3/3/2008
Old Mar 3, 2008 | 02:42 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (Chris Tune)
The one with the longest stroke always will because you're compressing 20mm, or about 31% more stroke (cylinder volume) into the same size combustion chamber as the engine with only 75mm stroke. The more volume you compress in a given space, the higher the compression ratio.
Old Mar 3, 2008 | 08:30 PM
Chris Tune's Avatar
Default Re: (00Red_SiR)
ding ding ding ding... U WIN
i hate the kids that tell me i have 12.5:1 pistons... OHHH REALLY???!!?!? pistons comes with all real numbers less the "estimated comp" which some FAIL to put somewhere that they are estimates!
"i have a b16a with 13.5:1 comp"... cause piston say 13.5:1...
gorillaglue#4
Sep 25, 2017 02:08 PM
CharliesEG
Oct 27, 2016 06:19 PM
doug118
May 13, 2009 11:37 PM
ShawnR
10
Jan 8, 2006 08:04 PM
steelies
Aug 23, 2005 06:21 AM
