Honda Accord Oil Leak After oil change
Old Feb 25, 2008 | 04:50 PM
TuningHonda's Avatar
Default Honda Accord Oil Leak After oil change
My winter car is a honda accord 1992 (no oil cooler).
I just changed my oil and filter and now there's a leak and it seems coming from the oil filter.
My question is, if the old gasket of the old oil filter still there (2 gasket). Ill be able to see it without taking of the filter? cause I look under the car and the filter seem to be sitting perfectly on the motor.
Another question, can an oil change make the oil sender start to leak??
I dont understand what is happening before there was no leak at all.. and now it leaking only when the car is running and right under the filter
Old Feb 25, 2008 | 04:56 PM
TheMuffinMan's Avatar
He knows where you live!
Did you change the crush washer?
Old Feb 25, 2008 | 05:43 PM
billyrusa's Avatar
Default Re: (TheMuffinMan)
If the oil filter leaks oil, remove the oil filter. Clean out the rubber seal and wipe off the seat on engine block. Apply a light coat of oil to the new oil filter rubber seal. Install the filter. After the rubber seal seats, turn the oil filter 7/8 - 1 turn.
Old Feb 26, 2008 | 12:56 PM
professorman's Avatar
Default Re: (billyrusa)
You do not have to change the oil or anything to remove the oil filter and check, so it is pretty easy to just take it off, make sure everything was clean and re-install it.
WingedMan
Aug 22, 2011 06:50 PM
chiaxi2002
Apr 9, 2010 08:56 PM
holmesnmanny
Dec 10, 2009 03:14 AM
wesk18
Dec 26, 2008 10:56 AM
NINJA
Aug 2, 2003 11:56 AM
