Used JDM front-end, will it fit right?
Old Jul 5, 2002 | 06:20 PM
Wet Nudl's Avatar
New User
Default Used JDM front-end, will it fit right?
Assuming all the parts are complete (nuts, bolts and what not).. Will I run into any fitment problem? thanks.
Old Jul 5, 2002 | 06:22 PM
uNF$@#!'s Avatar
Default Re: Used JDM front-end, will it fit right? (typeRP)
yes..you will run into the problem that it will you extra labor.
in the end it would have cost the same as a new front end unless you like cutting corners.
Old Jul 5, 2002 | 06:23 PM
B2FiNiTY's Avatar
Get a new oem metal jdm front with HIDs
Old Jul 5, 2002 | 06:25 PM
Wet Nudl's Avatar
New User
Default Re: Used JDM front-end, will it fit right? (B2FiNiTY)
icic.. Can someone back into me please?? hehe j/k.
thanks guys..
Old Jul 5, 2002 | 06:26 PM
BlueR's Avatar
how about i ram you head on...and we both get a new JDM front
Wet Nudl's Avatar
New User
Default Re: Used JDM front-end, will it fit right? (Soup ****)
Just for the record, what sort of problem(s) will I run into if I try putting on a used JDM frontend?
Old Jul 5, 2002 | 06:28 PM
Wet Nudl's Avatar
New User
Default Re: Used JDM front-end, will it fit right? (BlueR)
Cool man.. As long as you include the "I" statment in the report. I'll split your deductible with ya...
Old Jul 5, 2002 | 06:30 PM
B2FiNiTY's Avatar
Hit and run! I swear!! Plus if the car that is hitting you is black then that's always a plus.
Old Jul 5, 2002 | 06:32 PM
BlueR's Avatar
hey, b2 get in line, me foist!
Old Jul 5, 2002 | 06:36 PM
Wet Nudl's Avatar
New User
Ok BlueR, where and when do you want to do this? I'm sick and tired of waiting.. Dang, we are so bad. Conducting insurance fraud on the internet...
Old Jul 5, 2002 | 06:37 PM
B2FiNiTY's Avatar
LOL. I would love insurance to find this thread and start making accusations! But since BlueR is "1st" in line...heh heh heh...
Old Jul 5, 2002 | 06:38 PM
BlueR's Avatar
i've been waiting for 3 years already...anytime you're ready
Old Jul 5, 2002 | 06:55 PM
koy's Avatar
koy
New User
if your used JDM-front is the same color as your car , then it is just a matter of some welds and bolts and lining up the pieces for fitment.
Old Jul 5, 2002 | 06:59 PM
Wet Nudl's Avatar
New User
Default Re: Used JDM front-end, will it fit right? (koy)
And welding is not needed if you get new pieces?
BlueR's Avatar
welding is needed for the bumper support new or used...
[Modified by BlueR, 11:00 PM 7/5/2002]
Old Jul 5, 2002 | 07:13 PM
Reid's Avatar
Global Moderator
You weld the radiator support, not the bumper support.
Old Jul 5, 2002 | 07:16 PM
ITRbroham's Avatar
shit post warrior
Default Re: Used JDM front-end, will it fit right? (Reid)
Randy, I thought you were gonna' sell your ITR and get something new?
Old Jul 5, 2002 | 07:35 PM
Wet Nudl's Avatar
New User
Default Re: Used JDM front-end, will it fit right? (ITRbroham)
Well, selling the R is always a tough call for me.. I don't think I said anything about selling the R.. Although I'm alwasy on the look out for a nice NSX that I can afford..
Old Jul 6, 2002 | 05:49 AM
Petah's Avatar
HOw do you remove the old rad support? Will it weaken the chassis if it's not done properly??
Old Jul 6, 2002 | 06:24 AM
Big Teggie's Avatar
Default Re: Used JDM front-end, will it fit right? (eg-six)
I think you just carefully drill out the old spot welds.
Old Jul 6, 2002 | 07:10 AM
acuracing's Avatar
Default Re: Used JDM front-end, will it fit right? (Big Teggie)
Drill or chisel out the spot welds. Weld in the new radiator support. Bolt on. There should be no difference between a new or used JDM front (aside from dings, etc.). I purchased a used one before and had no problems whatsoever.
Old Feb 12, 2003 | 07:33 PM
Linger's Avatar
Default Re: Used JDM front-end, will it fit right? (acuracing)
I'll let you guys know when I get my car back........ I'm so nervous!
Old Feb 12, 2003 | 08:09 PM
Lucky-R's Avatar
hey randy...nice to see you back on HT
i've seen a jdm front conversion done before on an R using used parts and i have to say, i wouldn't have even known if it was ever a used front or not...i guess there are a lot of factors involved when choosing to go with a used piece, but the end product depends upon the the condition of course, and the talents of the people doing the conversion...
fitment and matching of the body panels is probably going to be the challenge (besides matching the paint too later on). you'd be surprised to find how many admit to having all, or part of their conversions done using used body panels...buying new of course can eliminate some worries and make the job easier, but either choice is a give and take...
i recently had to replace my oem fender with a used one, and although slight and almost invisible, there is a shift in the lines of the car between door and fender when looking at an angle. still, the fender was an easy unbolt and rebolt due to the oem exchange, and i couldn't be happier with the end result. i'd assume you would have the same success with a complete used front if it came off a car that was in newer, cherry condition.
whatever the case, don't take shortcuts...the R deserves your best
a
sampol999
Jun 25, 2007 08:34 PM
2fst4u2c
Dec 13, 2004 07:38 PM
confusedJDMvwGTI
Apr 16, 2004 08:02 PM
tmg
Aug 6, 2002 07:25 PM
