5th gen sunroof in 4th gen
Old Feb 25, 2008 | 03:12 PM
All-Motor-Junkie's Avatar
Default 5th gen sunroof in 4th gen
checked out faq's to best of my ability and search only pulled up random sunroof problems, i know this has been done before, the clear glass and i dont think you can cover the glass its just like that cause cover wont fit or somthing. anyways what i want to know is what mods needs to be done to fit this, or is it direct bolt on? thanks in advance and sorry if repost or i failed at finding this in faq's
Old Feb 25, 2008 | 03:35 PM
Default Re: 5th gen sunroof in 4th gen (All-Motor-Junkie)
bump~
Old Feb 25, 2008 | 03:52 PM
Apex1972's Avatar
I have done this swap. You need,
1. 97 up sunroof glass.
2. 97 up sunroof brackets.
3. A buddy to help.
4. small phillips head screwdriver
5. 10mm to remove the old sunroof after you remove the interior cover.
6. Remove your headliner and a pillar covers.
7. There is a metal tab that you will have to grind off of the new glass.
OK, after you remove your old sunroof and brackets, attach the 97 up brackets to your sunroof slider rails.Then attach your glass roof to the new brackets. There is a write up that used the existing brackets, if you cannot get the new brackets you can use the old ones. You will have to drill out a hole on each side though. I personally would not do it this way. Anyhow, after you get your glass attached to the brackets of your choice, you will notice that the glass sits too high. Get some washers , or body shims.
Now, loosen the 10mm bolts that hold the whole assembly to the roof of the car.This is where you might want an assistant. Your car will be slightly different from mine so you will have to see how many washers or shims will be needed. What you are doing is spacing the whole assembly down to make the glass nice and FLUSH. Good luck.
Old Feb 25, 2008 | 04:24 PM
'95 BA8's Avatar
Default Re: 5th gen sunroof in 4th gen (Apex1972)
From what i hear the fifth gen brackets makes the 4th gen sunroof motor struggle, which doesn't make sense to me, but I'm in the process of completing this conversion using the fifth gen brackets.
Here are the pictures of the glass roof on my extra fourth gen assembly, note the front is slightly higher than the rear when fully closed:
Old Feb 25, 2008 | 05:30 PM
awesome th anks for all the help, could you make a writeup w/ pics as you do it? specially what you have to "grind" wanna know what im getting into and how thing this might take, going on a daily driver
Old Feb 25, 2008 | 05:45 PM
lanemeyer14's Avatar
Default Re: (All-Motor-Junkie)
I did this swap a few years ago. Not very hard at all...did it by myself in an hour or two. I used my 4th gen brackets since i didn't have the 5th gen ones. Haven't had any problems so far.
Old Feb 26, 2008 | 02:44 AM
'95 BA8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All-Motor-Junkie &raquo;</TD></TR><TR><TD CLASS="quote">awesome th anks for all the help, could you make a writeup w/ pics as you do it? specially what you have to "grind" wanna know what im getting into and how thing this might take, going on a daily driver</TD></TR></TABLE>I already grinded down the parts, so you're a little late to ask me, but, if you look at your 5th gen glass there's a part with plastic tips that sticks out of the front on the underside, remove these tips and you should see two small metal towers/stoppers those are what you grind down, then on the sides the outer plastic which they call guiders has to be cut down by 1/4.
I'll do a write up from there on if you wish, I could find pictures of the parts I cut already.
Old Feb 26, 2008 | 05:27 AM
thad be nice, appreciated
Old Feb 26, 2008 | 09:04 AM
Apex1972's Avatar
Default Re: 5th gen sunroof in 4th gen ('95 BA8)
No problems with mine yet. I have about 2 or 3 extra motors anyway. But yes the front 6 bolts are the ones that I had to shim down.
Old Feb 26, 2008 | 09:05 AM
sean1121's Avatar
Check my sig, installed the entire 5g sunroof with cover.
Modified by sean1121 at 12:37 PM 2/26/2008
Old Feb 26, 2008 | 09:28 AM
Apex1972's Avatar
Default Re: 5th gen sunroof in 4th gen (sean1121)
Very nice. I could have done that , my friend took his whole assembly out of his 5th gen. I don't think I need the slider that bad though. Props on the mod though!!!!!
Old Feb 26, 2008 | 09:29 AM
BUILT93ludeSi's Avatar
you dont have to remove the head liners or a-pillars or any trim if you dont want to to do the instal. just have to open the sunroof enough to get to the bolts. basic mods include redrilling the holes on the 4th gen brackets to accept the glass sunroof bolt pattern (fth gen brackets wont let it sit flush), grinding off the tabs on the front of the glass sunroof, and triming the molding to let it sit flush on the top. here are some pics of the brackets to see the dif and also where i grinded off the tab on the glass sunroof and a finished pic...
http://i199.photobucket.com/al...1.jpg
http://i199.photobucket.com/al...6.jpg
http://i199.photobucket.com/al...e.jpg
Old Feb 26, 2008 | 09:34 AM
Default Re: 5th gen sunroof in 4th gen (BUILT93ludeSi)
also i dont think it would be the brackets making the motors strugle. from what i understand the glass sunroof is a little heavier so on an old 4th gen sunroof motor the extra weight is likely what causes more stress on the motors.
Old Feb 26, 2008 | 02:05 PM
Apex1972's Avatar
question, how does that 5g work does it pop out of the roof like the original 4g or does it retract into the roof??? please excuse my ignorance!!!!!
Old Feb 26, 2008 | 05:11 PM
'95 BA8's Avatar
It pops out like the fourth gen roof.
And the person who told me his motor struggled said it didn't with the fourth gen brackets, which is why I'm saying it makes no sense, UNLESS the brackets were somehow touching something.
OmarR's Avatar
here's the diy. http://www.superhonda.com/foru...13452/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BUILT93ludeSi &raquo;</TD></TR><TR><TD CLASS="quote">also i dont think it would be the brackets making the motors strugle. from what i understand the glass sunroof is a little heavier so on an old 4th gen sunroof motor the extra weight is likely what causes more stress on the motors.</TD></TR></TABLE>
The weight really isn't a big factor since the roof is only moving horizontally. If it was moving vertically, the weight could have an effect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apex1972 &raquo;</TD></TR><TR><TD CLASS="quote">question, how does that 5g work does it pop out of the roof like the original 4g or does it retract into the roof??? please excuse my ignorance!!!!!</TD></TR></TABLE>
The roof will retract exactly how the original 4th gen one did.
Old Feb 27, 2008 | 07:22 AM
Apex1972's Avatar
Default Re: 5th gen sunroof in 4th gen (OmarR)
but he installed a 5th gen assembly. I thought that one retracted into the roof and did not pop out. however, the 4th gen roof does not look long enough for that.
Old Feb 27, 2008 | 09:42 AM
wow thanks for these.
Old Feb 27, 2008 | 09:34 PM
streetracer6rpt's Avatar
i helped my friend put my old sunroof from my 5th gen in his 4th. its was pretty easy, if i remember right it pretty much bolted right in. i know we had 2 modify something, but i cant remember what it was.. it wasent anything big at all...very easy
RusBear
Dec 16, 2005 01:34 AM
skimeast1982
Dec 9, 2005 05:07 PM
pumafeet10
Oct 28, 2004 06:50 PM
bdb
Aug 5, 2004 03:50 AM
