EG hatch - Brake swap questions
I'm finally getting serious about my project car, its going to be a weekend cruiser/ auto -x learning car. eventually will be caged.
Currently a stock 93 Hatch CX, i have under the hood taken care of. I just need to keep it planted and be able to stop it quickly.
Current setup:
Stock 15" Acura Blades w/ 205 50 15 BFG Traction TA sport,
H&R springs - no camber correction
Skunk2 rear upper bar
No-Name front upper bar
I plan on getting Blox/Omni Rear lower arms, Koni adjustibles in the rear w/ some type of sway bar setup, and camber correction.
Front will likley be blox upper arms w/ Koni's and a Neuspeed upper bar, w/ 99 si front sway.
Any suggested setups for brakes? Budget is somewhat tight.
I'm mainly interested in getting discs on the rear, and bigger up front.
Thanks!
Current setup:
Thanks!
efbomb,
good pads and blank rotors should do the trick.
if you're going to upgrade your brakes, it would be ideal to swap to 94-00 integra front knuckles, which uses bigger calipers (stamped 17cl14vn) & 10.3" rotors. you'll need a bigger master cylinder (found from 91 civic ex, which bolts on to your 93 civic cx hatchback's master brake booster).
https://honda-tech.com/zerothread?id=820484
sirlaughsalot
Suspension & Brakes
56
Aug 20, 2009 12:27 PM
lopaka07
Oct 6, 2005 09:46 AM
CivicSiRacer
Feb 12, 2003 12:41 PM
