98 ITR rear Upper Control Arms (JDM)
Old Jul 5, 2002 | 05:16 PM
type r 01-1063's Avatar
Default 98 ITR rear Upper Control Arms (JDM)
Is this a worthwhile upgrade for $100?
What kind of benifits over regular USDM ITR?
btw - my car is daily driven
Old Jul 5, 2002 | 05:58 PM
Dropspeed's Avatar
Default Re: 98 ITR rear Upper Control Arms (type r 01-1063)
No, You can get adjustable ones to dial in the camber for about $55 a piece for steel ones, Aluninum is more money. They are heavy but effective. The JDM are better than the USDM because they are not a stamped part and they add a slight bit of camber in the rear. But if your going to change them, might as well get adjustable.
Mattj
[Modified by Dropspeed, 10:00 PM 7/5/2002]
Old Jul 5, 2002 | 06:20 PM
Asahi's Avatar
Default Re: 98 ITR rear Upper Control Arms (Dropspeed)
Who has adjustable ones for $55 and who has aluminum?
I assume you are talking about more than just camber correction?
Look like this?
Old Jul 5, 2002 | 07:11 PM
uNF$@#!'s Avatar
Default Re: 98 ITR rear Upper Control Arms (Asahi)
yes, look like those.
Old Jul 5, 2002 | 07:14 PM
Reid's Avatar
Global Moderator
Default Re: 98 ITR rear Upper Control Arms (Soup ****)
I wonder what kind of spherical bearings the King arms use.
Old Jul 5, 2002 | 07:16 PM
Asahi's Avatar
OK if you know what he was meaning can you share where to get them at $55? King has them listed for $400. I assume he meanst $110 for the set but still . . . Anyone
Old Jul 5, 2002 | 07:17 PM
Reid's Avatar
Global Moderator
I'm guessing $55 is referring to the Ingalls camber correction kit.
Old Jul 5, 2002 | 07:19 PM
Asahi's Avatar
Default Re: 98 ITR rear Upper Control Arms (Reid)
never seen an ingalls kit but they don't work like that do they? I wanna be able to add or remove camber and would prefer aluminum materials where applicable.
Old Jul 5, 2002 | 07:46 PM
Zeus's Avatar
I don't like my Ingalls kit... over priced and the poly bushings refuse not to squeak no matter what I use...
Old Jul 5, 2002 | 08:09 PM
Warren's Avatar
Wrong-Way Wang
Default Re: 98 ITR rear Upper Control Arms (Zeus)
You think polys are loud? Don't try spherical bearings then
Warren
Old Jul 5, 2002 | 09:22 PM
Zeus's Avatar
Default Re: 98 ITR rear Upper Control Arms (Warren)
Loud as in transfering noise is one thing... a cheese, cheap, constant creaking and squeaking is another Warren...
00 FBP ItR
Jan 27, 2004 12:45 PM
type r 01-1063
Sep 11, 2003 01:35 PM
jet
Oct 3, 2001 08:22 PM
albert butterbikini
Sep 21, 2001 02:18 PM
Rhetoric
Aug 11, 2001 05:57 PM
