transmission reverse idler gear washer
Old Feb 25, 2008 | 12:19 PM
ToeJam's Avatar
Default transmission reverse idler gear washer
I noticed that some b'series hydro trannys have them and some dont.
Can somebody please explain why washer #7 in the diagram is excluded in some transmission and included in others? If you know the purpose behind the washer please enlighten us.
Thank you.
Old Feb 25, 2008 | 12:26 PM
ToeJam's Avatar
Default Re: transmission reverse idler gear washer (ToeJam)
also, does anyone know if there is a difference in the reverse idler gear and shafts between the b'series trannys? can these be interchanged?
When compared side by side they look almost identical.
hmm..
Old Feb 26, 2008 | 12:54 PM
ToeJam's Avatar
bump
Old Feb 26, 2008 | 07:07 PM
ToeJam's Avatar
nvm, found my answer
Old Feb 26, 2008 | 07:55 PM
db1_jdm's Avatar
Im curious to know what was your answer
Old Feb 26, 2008 | 08:29 PM
ToeJam's Avatar
Default Re: transmission reverse idler gear washer (db1_jdm)
gsr and Ls have different reverse idler gears and shafts.
Gsr gears uses needle bearings in the gear and the shaft is solid. It needs the washer to get the proper height and clearance.
LS uses what seems like a brass bearing and the shaft have a split/groove in it for oiling. It needs no washer to get its height for clearance.
You can use either idler gear set in any hydro b'series tranny but you have to pair them up accordingly.
Bob Dole!
Transmission & Drivetrain
Apr 20, 2025 07:42 AM
Honda Bull
Oct 12, 2010 10:59 AM
Toda Party
Sep 18, 2003 09:17 AM
Burke
Jun 5, 2003 03:38 PM
