when shifting to second gear the car junks real quickly is cause of the under drive crank pully?
Old Feb 25, 2008 | 11:52 AM
igotjshoe's Avatar
Default when shifting to second gear the car junks real quickly is cause of the under drive crank pully?
my car has been juckin to second for the last year it a automatic i was wondering is cause of my underdrive pulley
TheMuffinMan's Avatar
He knows where you live!
juckin = english ?
Old Feb 25, 2008 | 03:54 PM
igotjshoe's Avatar
Default Re: (TheMuffinMan)
meaning it feels like someone is doing a quick tug on the car when it shifts to second
Old Feb 25, 2008 | 07:33 PM
mrmjn111's Avatar
Default Re: (igotjshoe)
year? usually the accord automatics have a rough shifts...but that may just be for the cd5's which is what i have
Old Feb 25, 2008 | 07:48 PM
Jerks?
There can be a rough transition between gears in some year accords, I've experienced it on my 97.
Old Feb 27, 2008 | 04:50 AM
igotjshoe's Avatar
should i remove my crank pulley an put back the alt pulley
Old Feb 27, 2008 | 09:56 AM
not-a-stang's Avatar
the pulleys have nothing to do with shifting... check your trans fluid or have it replaced/serviced. Maybe its gunking up inside and causing the harsh shifts.
for what its worth, nearly all hondas I've driven have a momentary jerk between the 1-2 shift. Its normal.
misterpsycho
Oct 28, 2008 05:23 PM
redzcstandardhatch
Jul 22, 2007 03:44 PM
mjfubar101
May 7, 2007 07:41 PM
VisualEcstasy
Apr 22, 2003 02:44 PM
Kevin
May 17, 2002 08:51 AM
