cruise control button stuck down on 96 accord
Old Feb 25, 2008 | 09:19 AM
schillage's Avatar
Default cruise control button stuck down on 96 accord
the cruise control button is stuck in the down position and not working? is it a fuse problem or is there any easy fix. or am i out of luck. any incite would be great
Old Feb 26, 2008 | 12:59 PM
professorman's Avatar
Default Re: cruise control button stuck down on 96 accord (schillage)
Which one of the cruise control buttons? The MAIN cruise control button or one of the accelerated/decelerate buttons on the steering wheel? Try working it out with a small little knife or spray something in there (maybe WD40, or alcohol, or GooGone) and see if you can loosen it up if it is just binding. My 4-way flasher switch binds sometimes in winter months when I turn it on, and I have to work it out with a little pocket knife. That switch has a little spring behind it to pop it back up after you press it down.
Old Feb 26, 2008 | 03:32 PM
schillage's Avatar
Default Re: cruise control button stuck down on 96 accord (professorman)
I will give it a go, it is the main cruise control button.
bleedblue94
Jun 21, 2009 08:48 AM
bleedblue94
Jun 20, 2009 10:39 PM
Elvis1977
Jan 13, 2004 10:52 AM
ophdehEEzY
Jun 26, 2003 05:12 AM
