Suspension & Brakes Theory, alignment, spring rates....
Are bump stops needed for Skunk2 full coilover?
Old Feb 25, 2008 | 08:46 AM
Civic858's Avatar
Default Are bump stops needed for Skunk2 full coilover?
Do I need bump stops for a set of Skunk2 full coilover, the kit didn't come with any. I'm planning to drop a TSX.
Old Feb 25, 2008 | 12:25 PM
EK_B's Avatar
Wait, don't full coilovers come assembled with top hats and all?
Old Feb 25, 2008 | 01:14 PM
Civic858's Avatar
Default Re: Are bump stops needed for Skunk2 full coilover? (Civic858)
I just called Skunk2 and they said I need a set of bump stops.
Old Feb 25, 2008 | 01:26 PM
omnirage's Avatar
Pfft...unless you're dropping more than 2" or rally racing around some crazy dunes then you wont need them. Trust me.
They're stiff enough to tackle bad roads. You'll be uncomfortable as hell over rough asphalt, but you're not going to bottom out. Not even close.
Edit: My experience is with a Teg, I only just noticed you're fitting them onto a TSX.
Old Feb 25, 2008 | 02:23 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic858 &raquo;</TD></TR><TR><TD CLASS="quote">I just called Skunk2 and they said I need a set of bump stops.</TD></TR></TABLE>
If Skunk2 told you that you need bump stops, then put bump stops on them.
You don't want to bottom out the dampers internally and damage them, because you'll be SOL when you have to buy another set.
riciv97
May 7, 2009 04:45 PM
slambedcivic
Feb 22, 2009 06:38 PM
90 JDM EF8
May 7, 2007 12:58 PM
94gsr_teg
Apr 19, 2006 03:34 PM
