Check Egine light came back.
Old Feb 25, 2008 | 06:32 AM
deklao's Avatar
Default Check Egine light came back.
I got Code 12 - EGR valve clogged problem or something. I took it out and cleaned it. I also cleaned the 4 passage on the intake where this EGR valve feeds the access gas. Drove it for 100 miles. Light came back on. I stopped the car and pull the vacuum hose that connects to EGR valve. No suction. Should it has suction when the car has been running for 35 mile and temp is at normal operating range?
thanks
Old Feb 25, 2008 | 08:10 PM
deklao's Avatar
well, I trace the vacuum line to the black box on the fire wall. I found the vacuum lines were pinched at the throttle body. I trimmed the vacuum line and plugs them back on. Will see tomorrow if this fix the problem......
yzracer
Oct 2, 2011 04:23 AM
MKT
Aug 2, 2011 01:46 PM
diyguy13
Sep 12, 2008 08:43 AM
eli_s
Mar 19, 2006 10:14 PM
darrenwall
Aug 27, 2002 06:34 AM
