Passenger Airbag Removal For OEM Tray
I am going to be removing the passenger airbag to put in an oem honda tray This is both a track and show car. My question is other than the obvious disconnecting the battery and being safe while doing it, will the SRS light come on once it is removed? If so any way of disabling the light and will it affect the use of the driver side airbag?
This might seem like a ridiculous question, but if you removed both airbags, you would need two resistor plugs, one to simulate each airbag correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondastrtracr »</TD></TR><TR><TD CLASS="quote">I am going to be removing the passenger airbag to put in an oem honda tray This is both a track and show car. My question is other than the obvious disconnecting the battery and being safe while doing it, will the SRS light come on once it is removed? If so any way of disabling the light and will it affect the use of the driver side airbag?</TD></TR></TABLE>
Take out the complete system and take out the bulb on the cluster
If I do decide to put a after market steering wheel on also if I pull the srs box will it disable the whole system and not cause any problems?
HULKHATCH10
Mar 16, 2005 04:40 PM
