2006 rsx paint how many gallons
Old Feb 24, 2008 | 08:35 PM
CaliforniaK's Avatar
Default 2006 rsx paint how many gallons
how many gallons of paint will i need to cover up the car and door jams as well as clear and primer thanks
Old Feb 24, 2008 | 10:15 PM
T-Rock's Avatar
Default Re: 2006 rsx paint how many gallons (CaliforniaK)
Probably about three quarts of base coat with reducers, and usually clear is cheapest by the gallon, as far as the base coat goes it really depends onthe color but three quarts should do, also two quarts to a gallon of sealer. Most of the amounts really depend on the mixing ratio of the paint system you are using, for example if the base coat is a 1:1 mix ratio 1 part being color the other part being reducer then 1 pint of color would make 1 sprayable quart mixed with the reducer.But three quarts is usually what I get for a moderate sized car.
Old Feb 25, 2008 | 11:51 AM
Default Re: 2006 rsx paint how many gallons (T-Rock)
thanks
94_Teggy
Paint and Body
11
Dec 10, 2009 01:46 AM
MrSalenga
10
Jun 3, 2009 10:46 AM
Soon2bH2b
Paint and Body
26
Sep 22, 2007 02:38 PM
ek4shizzle
Paint and Body
18
Aug 28, 2007 11:37 AM
hondaboy90
Feb 16, 2006 05:12 AM
