Fog light problem. DA & electrical experts please!
Old Feb 24, 2008 | 08:06 PM
Ricextacy's Avatar
Default Fog light problem. DA & electrical experts please!
driver side is dimmer then the passenger side.
i tired replacing the bulb but still dim
checked my connections and fuses.
checked a part of my ground but dont kno where else it can be touching.
any suggestions?
just got out of the rain, and da housing is painted black. so bare with me on the pic.
passenger side 100% perfect. Driver 80% bright
Old Feb 25, 2008 | 11:26 AM
meCka's Avatar
bump cuz i have the same problem
Old Feb 25, 2008 | 11:57 AM
super jdm yo's Avatar
Default Re: (meCka)
i had that same problem well i brought a new driver-side headlight. i took apart the head-light and found out that the yellow cover had this build up that blocked most of the light, causing it to be dim. i tried to clean it off with various cleaners and it wouldn't come off. till i sanded it down. but it sanded some yellow off too.
my best suggestion would be just get some new clean yellow covers.
Old Feb 25, 2008 | 12:02 PM
Perfectionist's Avatar
Default Re: Fog light problem. DA & electrical experts please! (Ricextacy)
A dim lamp would indicate either not enough current is getting to the lamp from the supply wire (poor relay contacts, corroded or partially broken conductor, etc), or the ground wire isn't passing enough current (broken conductor, corroded connection, etc).
Old Feb 28, 2008 | 12:23 PM
Ricextacy's Avatar
Default Re: Fog light problem. DA & electrical experts please! (Perfectionist)
o fo sho. if it would be the bulb cover? where would i be able to find one..wow Perfectionist your pretty smart. but im hella noob when it comes to electrical. ima ask my boi to check these things. thx!
Kamikaze
Aug 4, 2006 07:35 PM
mugenracer
Apr 11, 2005 07:07 PM
NewBorn_EG
Nov 14, 2004 04:08 AM
Weapon_R
Nov 12, 2004 07:29 PM
tND2k
Jul 15, 2003 10:59 PM
