Electrical Problem: Cluster, Radio, nd cig lighter lost power & "key reminder" beep wont stop
Old Feb 24, 2008 | 01:59 PM
StreetRiot_DRE's Avatar
Default Electrical Problem: Cluster, Radio, nd cig lighter lost power & "key reminder" beep wont stop
i have a 1994 integ Ls...there was a problem with my radio and cig lighter not working, so i fixed it; it was a lose ground for tha radio nd no power to the lighter...Ok this is where tha problem started: i used a test light 2 find tha ecc power wire from my radio harness and direct wired my cig lighter. Everything worked fine when i put the key 2 "on" position without starting tha car. Then when i turned the car on the radio had no power nd neither did tha cig lighter and to make thing worse my gauge cluster lost power nd now none of tha gauges (except gas) work...Any ideas on tha issue??
oh nd incase it make a difference: i had adjusted my idle b4 starting the work inside and was workin on tha radio and lighter with the fuse for ECU pulled 2 reset tha ecu..(ecu reset procedure done as recommened on "teamintegra.net)
oh yeah nd also now when tha key is in tha ignition with it in any postion, except off, and tha door open tha lil "key reminder" chime/beep doesnt stop. And theres no noice with tha key in tha ignition but in the off postion.
Old Feb 24, 2008 | 02:34 PM
Default Re: Electrical Problem: Cluster, Radio, nd cig lighter lost power & "key reminder" beep wont stop (S
bump 4 some help
Old Feb 24, 2008 | 04:36 PM
BoSox46GSr's Avatar
I had some similat problems with my DA, somehow i blew a bunch of fuses. My gauge cluster went out, taillights, door sensor, radio etc...
Old Feb 25, 2008 | 01:36 PM
yeah that wut kept happening 2 this car, but it ended up being that some wires were mixed up nd wired wrong....all fixed now tho
99hcdx
Jan 31, 2010 08:16 AM
Sadus
May 19, 2007 09:15 AM
CIVIC dude
11
May 10, 2005 10:52 AM
HondaPartsHero
Aug 25, 2003 05:29 PM
