wet floor problem on 91' crx
Old Feb 24, 2008 | 10:33 AM
bman1990's Avatar
Default wet floor problem on 91' crx
the floor on the passenger side in my crx gets wet after driving in the rain and even if its just sittin out in the rain. i cant figure out the problem....i dont see a leak on that side and the bottom looks normal. should i strip the whole floor or is there an easier way to find the leak???
Old Feb 24, 2008 | 10:45 AM
v.i.massive's Avatar
do you have a sunroof if so you might to check and if the drain hose for the sunroof is connected to the sunroof drainif its not reattach
Old Feb 24, 2008 | 10:46 AM
HondaHeddie's Avatar
Default Re: wet floor problem on 91' crx (bman1990)
you definitely need to fix this
till you find the leak I would keep the carpet pulled down so the ecu is not trapped under it with moisture
water+ecu= very dead crx
make sure the ecu can breathe
Old Feb 25, 2008 | 05:22 PM
CR91X's Avatar
Check your windshield from the inside and see where it's wet/leaking from. I didn't have a wet floor but had a tiny leak(a while ago). If the windshield moldiings/trims weren't put on right/caulked good -it might have leaked from there. <----- something like that hopefully you know what I mean and just check from the inside under the windshield, just look all around and you should be able to see if it's wet/leaking at a certain spot or not. That's if you don't have a sunroof. I didn't have one but your problem kinda sounded like what happened to me. Good luck
BadassEFdriver
Mar 17, 2010 08:56 AM
doom26464
Aug 5, 2008 08:36 PM
sozzer
Apr 1, 2008 09:40 PM
classciv
Apr 7, 2006 06:22 AM
91IntegraX
Oct 24, 2004 07:23 AM
