23mm type r sway bar bushings??
Installing a 23 mm jdm type r sway bar in the rear i have the blox adjustable endlinks and the new oem mounts how ever ive searched all day and have come up with no answer for the bushings required in the ends of the bar itself they are availible from acura part 8-11 in the diagram on acuraoemparts.com but i am not sure in the diametre of the hole is the same size for the type r sway bar, i know the gsr and ls are the same part number but is the jdm type r different ??
in this picture the guy used metal spacer or washers in the place of the oem rubber bushing i would rather go with the oem setup if availible or es bushing however cant seem to find them nor do i know the size of the hol in the bar since i have yet to recieve the bar that i bought. any help or ideas would be awesome thanks
