CRX noise elimination hatch squeak dash rattle
Old Feb 24, 2008 | 09:45 AM
RockinthEFhatch's Avatar
Default CRX noise elimination hatch squeak dash rattle
Alright so I got all the electrical problems fixed in my car and even put my Alpine back in - turns out I needed a new battery . At any rate my dash has always rattled as well as my hatch while driving and I was wondering if anyone knows exactly what it is or has experienced this before. I believe two sources are; the outside air vent switcher and the temp **** screws on the back of the climate control. And my hatch rattles and sqeaks as well through searching I read you can tape electrical tape on the metal loop and fully unscrew the rubber stoppers but has anyone successfully eliminated all their noise issues?
Old Feb 24, 2008 | 09:52 AM
Default Re: CRX noise elimination hatch squeak dash rattle (RockinthEFhatch)
A picture of my dash to inspire thought
Old Feb 24, 2008 | 12:53 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
the electrical tapr works great, even at high speeds. still cant figure out the dash noise yet
Old Feb 24, 2008 | 03:49 PM
Nihilus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockinthEFhatch &raquo;</TD></TR><TR><TD CLASS="quote">
A picture of my dash to inspire thought </TD></TR></TABLE>
Hey, it's my old dashboard.
Old Feb 25, 2008 | 01:56 AM
traxxasx's Avatar
man i been messing with the hatch on mine forever. Its always sqeaking when i hit bumps and when i turn it rattles and shakes. I been messin with the rubber stops and everything else....
MY DASH RATTLES 2!! Damn its so annoying. I tighten every bolt under the dash. But i dont know how to remove the air vent to tighten the ones on the side of the dash. So maybe thats it.....
Wow WE need some help.
He whats the tape thing ABOUT?
Old Feb 25, 2008 | 08:18 AM
scrboro's Avatar
Default Re: (traxxasx)
The tape thing is for the hatch rattle.
Old Feb 25, 2008 | 08:30 AM
The Bus Driver's Avatar
Sometimes my dash rattles when I'm at a red light.
I just put the car in neutral and it goes away instantly.
Any thoughts as to how I can silence the noise without putting the car in neutral?
Old Feb 25, 2008 | 08:39 AM
YLWCRX's Avatar
Default Re: (The Bus Driver)
For the hatch squeaks/rattles I would replace the gas struts that help hold up the hatch. They get worn out and allow the hatch to move slightly when you get bumps and uneven pavement. I have had this issue in all of my EF's, I have had 4 so far, and the struts have made the big difference.
Old Feb 25, 2008 | 08:44 AM
90goldhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Bus Driver &raquo;</TD></TR><TR><TD CLASS="quote">Sometimes my dash rattles when I'm at a red light.
x2 but when i take off it goes away
Old Feb 25, 2008 | 10:23 AM
Default Re: (dczchatch)
The tape on the hatch works well. I am still having issues with echo-locating the sounds from my dash. I now believe my radio has something to do with it as well as my climate control ****. I am taking it all apart tonight.
Old Feb 25, 2008 | 10:26 AM
Default Re: CRX noise elimination hatch squeak dash rattle (Nihilus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nihilus &raquo;</TD></TR><TR><TD CLASS="quote">
Hey, it's my old dashboard. </TD></TR></TABLE>
It's actually not... this picture was from right before I nicked mine and had to put yours in. My old dash was absolutely flawless too, never made a sound - a shame I had that gay *** short throw in the car which led to misinstallation of the console
Old Feb 25, 2008 | 10:34 AM
89efDUSTY's Avatar
When I had my old rex I made a hatch bracing bar between the trunk strut bolts and it cleared up the noise...plus my JDM factor went up like crazy
Old Feb 25, 2008 | 10:49 AM
DontFlameMeBro's Avatar
Default Re: CRX noise elimination hatch squeak dash rattle (89efDUSTY)
I fixed my hatch squeak by unscrewing the latch and removing the metal spacer plate behind it. It allows the hatch to close tighter. The noise never came back.
Old Feb 25, 2008 | 11:13 AM
ludesrv's Avatar
Use double sided tape on all mating surface for your dash. Make sure everything is tight and your squeaks should go away.
Old Feb 25, 2008 | 11:47 AM
rexie's Avatar
for the hatch on my old rex happend cuz it was slightly bent dont know if urs is but u might want to cheak and for the dash it might have been worped a little bit when u put it in so its not sitting right i would try that tape idea sounds like it would work
Old Feb 25, 2008 | 12:01 PM
Default Re: CRX noise elimination hatch squeak dash rattle (rexie)
Let's say my dashboard was warped, is there any technique to straightening it?
Old Feb 25, 2008 | 05:01 PM
traxxasx's Avatar
Ok but where does the tape go on the hatch? On the metal loop that locks it down? Just tape it up or what...
Old Feb 25, 2008 | 09:03 PM
JokerX-1.6T's Avatar
put some tape on the metal loop and be done with it mine has been quiet ever since - just do enough so it closes nice an secure like 10 months now.
Old Feb 25, 2008 | 10:37 PM
tico's Avatar
ihey guys the tape around the loop thing is a great tip did it on a friends and worked perfect. but when i did it on my 88std still the noise was as strong b4 i did it. turned out to be the hatch seal. i live in socal so the sumer can be brutal on rubber especially this old rubber. it sorta polishes the contact area and the struts do allow it to move a lil so add those together and u get some annoying *** squeaking. i took a scotch bright pad and GENTLY went around the hatch seal to roughen it up a bit. tightend down the struts a bit, took her for a spin. nothing but silence. but becareful if u do what i did, u can easily damage or even tear that seal. and if so its about 160 through honda and u have to wait 2+ days to get it. try wetting the pad if a lil nervous it helps lubricate it and keeps u from rubbing to hard.
Old Feb 26, 2008 | 01:17 AM
~sp33~'s Avatar
EFB055
My door locks rattle :/
Old Feb 26, 2008 | 06:39 AM
4d96gsr's Avatar
Default Re: (~sp33~)
my cd player skips no solution
Old Feb 26, 2008 | 09:19 AM
Default Re: (4d96gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4d96gsr &raquo;</TD></TR><TR><TD CLASS="quote">my cd player skips no solution</TD></TR></TABLE>That happened to me then I got an iPod interface for my headunit and nothing skips now since it's digital
Old Feb 26, 2008 | 09:39 AM
SETI20's Avatar
Default Re: (RockinthEFhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockinthEFhatch &raquo;</TD></TR><TR><TD CLASS="quote">That happened to me then I got an iPod interface for my headunit and nothing skips now since it's digital </TD></TR></TABLE>CD players are digital too. LOL
Solid state storage FTW. Even Ipod hard drives skip every now and then.
Old Feb 26, 2008 | 09:55 AM
schueytenten's Avatar
My little baby has almost 260K miles. The entire car squeeks. Where should I start?
Old Feb 26, 2008 | 10:33 AM
Tippyman's Avatar
Default Re: CRX noise elimination (schueytenten)
Lol. If I tried to fix all my rattles my car would weigh about 100 lbs more.
Squeaks = light = racecar.
