b16 w/ ctr pistons
Old Feb 24, 2008 | 08:59 AM
rex89sir2's Avatar
Default b16 w/ ctr pistons
ok well my question is i wanna do ctr pistons in my b16 while i got it torn down the question i have it my head is milled 30 thousand and with the ctr piston my compression will be 12.5.1 but i worried about my clearances has anyone every tried this and i really dont wanna have to clay if i dont have to.
Old Feb 26, 2008 | 12:39 PM
delsol vti's Avatar
Default Re: b16 w/ ctr pistons (rex89sir2)
hmmm, you don't have this compression.
if mugen 0.3mm head gasket put more 0.5/1 comp. ratio.(stock is 0.7mm)
0.30mm don't give to you this compression.
if you only put the pistons, you have 11/1.
with 30 thousand you have around 11.3/1 comp.
i have ycp ctr pistons in my b16A2, with 0.10 milled block.
and the head is milled 0.30, like yours!
Old Feb 26, 2008 | 06:17 PM
MightyMouseTech's Avatar
Do it, and buy my pistons.. LOL.
Old Mar 18, 2008 | 08:58 PM
RC_Barney's Avatar
Default Re: b16 w/ ctr pistons (MightyMouseTech)
i just did the same setup. but i used .25 over ctr pistons. It runs good but the only prob. is that u have to retard the timing alittle on pump gas
Old Apr 23, 2008 | 01:13 AM
jSPECx's Avatar
i bought a b16 too and the ctr pistons gotta be put in but the guy i bought it from said the the compessions to high and that it might mess up my valves. i dont know what imma do. either buy stock b16 pistons or have my rods milled and put in. anyone got any options?
Old Apr 23, 2008 | 06:11 AM
EKhatch's Avatar
Default Re: b16 w/ ctr pistons (delsol vti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsol vti &raquo;</TD></TR><TR><TD CLASS="quote">if you only put the pistons, you have 11/1.
Where did you get these numbers? I am pretty sure stock B16 block/head with CTR's is well over 11:1.
Old Apr 23, 2008 | 06:30 AM
IT GUY's Avatar
Default Re: b16 w/ ctr pistons (EKhatch)
zealautowerks compression calculator
If you add the head milling towards the bottom of the calculator you see that the CR is 13.2:1 with CTR pistons in a b16. The compression height on the CTR pistons is .73mm higher in addition to the large dome. I wouldn't try it without claying the motor.
JDM Lyfestyle
Jan 31, 2009 05:51 PM
iLOVEmyEMone
Nov 14, 2005 11:00 PM
aris04
Jun 4, 2004 10:38 PM
RICE POLICE SIP
Mar 9, 2003 12:25 AM
