*help!!!!* SCAT 92mm stroker crank
Ok guys I'm in the market for a 92mm scat crank but I just have a few a ?s
I already have custom cp slugs made for my stock gsr 87mm crank and rods is there a way I can use these pistons with this crank and get different rods? Who makes the rods that I need? I know usually they change the pin location on the piston but I wanna keep these pistons help me out please!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16FlatBack »</TD></TR><TR><TD CLASS="quote">OK I ENDED UP goin with pauter rods custom so hopefully I make good power</TD></TR></TABLE>
rods that make power FTW...
please fill me in on this rod that makes good power yo!!
its easier to use a std rod, ideally slightly longer to give back a lil bit rod ratio, then have pistons made with respective compression height.
Endyn uses the crower 92mm crankshaft with a .137 longrod and their custom rollwerwaves.
I have a set of rods and pistons for use with a 92mm crank, and I'm in nj. just pm if interested but mine are 86mm and 86.5mm
TurboJesse
Feb 20, 2006 05:57 PM
