noob saying hello , with a question
Old Feb 24, 2008 | 04:03 AM
beecee's Avatar
Default noob saying hello , with a GROUND CONTROL question
hi all , a lil intro , im from Dublin Ireland and drive a jdm 1.5x crx in flint black , which i was the first owner of from when it was imported . the car is in the body shop at the moment having the years of dings and dents sorted out and a full respray .i am trying to do something a little different with the car , looking for products that aren't readily available here in Ireland , im on a tight budget so cost is an issue , ive previously sourced an elemental designs sound system for the car , ive ordered a tenrai full stainless steel exhaust , ill change the muffler asap .next is suspension .. i want to get a full GC coil over set up and new shocks etc , the car will be my daily driver with the very odd track day , part numbers ,spring rates etc any help and any advice is appreciated , as getting this info over here is very difficult , cheers in advance BRIAN .
Modified by beecee at 8:06 AM 2/24/2008
Old Feb 24, 2008 | 05:40 AM
~sp33~'s Avatar
EFB055
Hey Brian.
The 1.5x was twin carb wasn't it? They're fun to play with. But a pain in the backside if they're not tuned correctly.
Im also pretty sure all twin carby models had a 4-2-1 header which means you will get negligible gains from any exhaust you fit.
I have heard of replacing the stock air filter with two single bike filters which sit in the mouth of the carburetter though. Apparently people have noticed gains with that, and im sure it would sound much better as well.
Good luck with your car.
Steve.
Old Feb 24, 2008 | 07:05 AM
beecee's Avatar
Default Re: (~sp33~)
hi , yeah ive done a few carb mods ,and have the bike filters waiting to go on , ive advanced the timing etc , so it runs and pulls a lot better .
Old Feb 24, 2008 | 07:11 AM
II 1ND3X II's Avatar
Are we talking Gen 1 or 2 CRX?
As ~sp33~ said there's not much to be had from the 1.5 Carby engine,
Best would be considering either a D or B series conversion with your coin before purchasing bits like I/H/E.
Old Feb 24, 2008 | 08:14 AM
beecee's Avatar
Default Re: (II 1ND3X II)
gen2 , with the carb and filter mods , you can get 130bhp ( dyno proven ) which is about he same as a stock sir , would prob cinsider an engine swap further down the line .
Old Feb 26, 2008 | 10:21 PM
Never played with a honda carby engine.
I see what you mean though... 130bhp 1.5 ftw!
Old Feb 26, 2008 | 10:38 PM
290allen's Avatar
what ecu is in the carb model. or is there one. i have a set that i have had sittin in my garage for almost 2 years now. been thinking about builing a carbed crx.
thanks
Old Feb 26, 2008 | 10:47 PM
^^ WTF?
Old Feb 27, 2008 | 05:36 AM
milesj27's Avatar
Default Re: noob saying hello , with a GROUND CONTROL question (beecee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beecee &raquo;</TD></TR><TR><TD CLASS="quote">.next is suspension .. i want to get a full GC coil over set up and new shocks etc , the car will be my daily driver with the very odd track day , part numbers ,spring rates etc any help and any advice is appreciated , as getting this info over here is very difficult , cheers in advance BRIAN .
Modified by beecee at 8:06 AM 2/24/2008</TD></TR></TABLE>
I'd give the Tein Super Street with Pillowball mounts a thought.
Spring Rates:
8 kgf/mm 450 lbs/in Front
4 kgf/mm 220 lbs/in Rear
Height Adjustment Range
Max/Min(mm/inch)
-8.0 / -0.31 to -79.0 / -3.11 Front
-2.0 / -0.08 to -70.0 / -2.76 Rear
Works with their EDFC so you can change your damping rates on the fly. It's a sweet setup that I'm considering for my own car, once I find an EF Si that is.
Good luck.
Old Feb 27, 2008 | 06:44 AM
beecee's Avatar
Default Re: noob saying hello , with a GROUND CONTROL question (milesj27)
how would the tein set up compare price wise in the states , as tein are major bucks over here ,( ireland ) .
im only learning but there are a few tricks you can do with the carbs , cuting the spring etc that make a great diferance .
Old Feb 27, 2008 | 08:28 AM
Si-Samuri's Avatar
welcome this site is your key to success.
Old Feb 28, 2008 | 01:27 PM
milesj27's Avatar
The Tein Super Street with Pillowball mounts is $1340 USD for the 89-91 CRX/Civic
Old Feb 29, 2008 | 04:52 AM
beecee's Avatar
thanks , cheers .
Old Feb 29, 2008 | 06:09 AM
~sp33~'s Avatar
EFB055
Default Re: (290allen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 290allen &raquo;</TD></TR><TR><TD CLASS="quote">what ecu is in the carb model. or is there one. i have a set that i have had sittin in my garage for almost 2 years now. been thinking about builing a carbed crx.
thanks</TD></TR></TABLE>
There is an ECU. Its actually PGM-Carb. Electronic Carb injection.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beecee &raquo;</TD></TR><TR><TD CLASS="quote">gen2 , with the carb and filter mods , you can get 130bhp ( dyno proven ) which is about he same as a stock sir , would prob cinsider an engine swap further down the line .</TD></TR></TABLE>
The SIR had 160hp, but the Si model had around 130hp.
Stock, the twin carb model developed 72kw. Which is on the shy side of 105hp, 13hp MORE then the US dpfi 1.5L
Carbs ftmfw.
Old Mar 11, 2008 | 05:24 AM
beecee's Avatar
oops getting mixed up between my jdm usdm edm monikers , but you get what i mean anyway . my car has been in body shop for 2 months now ,full respray been done at a good price as a favour , so have to wait and not complain about how long its taking . cheers Brian
eduran313
Suspension & Brakes
Feb 9, 2012 08:13 PM
divisionskate
Suspension & Brakes
Jul 20, 2006 04:34 PM
funkified
Suspension & Brakes
Jul 10, 2006 10:20 PM
Stinkycheezmonky
Oct 21, 2005 06:24 PM
Jake
May 3, 2005 03:32 PM
