will a b16 crank pulley fit on a b18c1?
Old Feb 23, 2008 | 04:41 PM
boostedgsr1234's Avatar
Default will a b16 crank pulley fit on a b18c1?
like the tittle says
thanks
Old Mar 19, 2008 | 09:01 PM
EK 2 9K's Avatar
Default Re: will a b16 crank pulley fit on a b18c1? (boostedgsr1234)
sorry to bring back an old thread and tread jack but i also need to know....ASAP
Old Mar 19, 2008 | 09:25 PM
jhammond_82's Avatar
Reject Papi
Default Re: will a b16 crank pulley fit on a b18c1? (EK 2 9K)
the blocks are the same, so i would assume that the pulley's would be interchangeable.
Old Mar 19, 2008 | 09:36 PM
UmbraDc2K's Avatar
Default Re: will a b16 crank pulley fit on a b18c1? (jhammond_82)
I thought you'd need longer rods because of the different stroke.
Old Mar 19, 2008 | 11:32 PM
dcRay's Avatar
The pulley itself would fit, but it is a tad smaller than the 1.8 pulley. Hence you would need to compensate when timing it.
Old Mar 20, 2008 | 09:36 AM
jomama's Avatar
yes, it'll work... but the b16 crank will net you much less stroke (77.40mm vs 87.20mm) so assuming you went with b16 rods and kept everything else the same... this would give you a whopping 5.18:1 compression ration with 1595cc displacement. if you stuck with c1 rods, you'd have a KILLER 6.30:1 compression ratio and 1596cc displacement still. (the OEM C1 compression ratio is 10:1 and 1797cc displacement)... in short, this is pretty stupid to do unless you have something up your sleeve... were you thinking about using a b18 crank and rod for a "stroked" gsr and just got your engine codes messed up ?
Modified by jomama at 10:46 AM 3/20/2008
wunfstgsr
Jan 27, 2009 08:28 PM
Spec R_GSR
Jan 15, 2007 11:48 AM
kuja
Jun 9, 2005 07:11 AM
MenaceL.A.671
Jun 29, 2004 05:50 PM
riceball777
Feb 2, 2004 11:55 AM
