Would this setup make a good DD, while staying reliable?
Planning on purchasing a EK coupe with..
Engine-
Block: fully built by JG Engine dynamics w/ receipts to prove.
Block hot tanked & cleaned.Deck block surface microfinished.
Micropolished crank & ultrabalanced. Bore of 84mm.
Power honed & finished w/ Sunnen AN300 stones.
ACL Bearings for main, rods & thrust. JGE 4340 ultralight beam rods.
84mm CP pistons & CP rings. New rear main seal. Type R oil pump.
84mm Cometic head gasket 0.51mm.
Fully assembled by JG & fished off in JG gold, Powdercoat Block.
Head: Fully built by Extreme Cylinder Heads, of Palm City, FL.
Blox Stage II cams.
Ferrera valves. Skunk 2 Titanium retainers. Dual valve springs.
Ported & Polished. 3 Angle valve job.
ARP Head studs. JGE 6-bolt cam gears.
Password JDM cam seal.
Bolt-ons Ect:
Blox intake manifold.
Comptech USA cold air intake. (Full Kit)
Vision 4 to 1 Headers.
Apexi Full Catback Exhaust. (World Sport)
Mishimoto radiator w/ blue samco sport hoses.
Blox fuel pressure regulator. B & M fuel pressure gauge.
Golden Eagle fuel rail. RC 310cc injectors. NGK wires.
accel performance coil. Hasport motor mounts. Password JDM cooling plate.
Could this setup be a good daily driver? Will it be reliable? Is there any extra maintence that this would require? How much power do you think this setup could make?
Engine-
Blox Stage II cams.
Bolt-ons Ect:
yeah its a nice set up. and get it dyno tune afterwards.
for daily drive. it might not idel as normal before because aggressive cams and higher compression pistons.
The guy says its already tuned moderatly by "Mase". But didn't say how much HP it has. What would you assume a setup like this would make? 200whp? 220whp?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">That's a pretty stout engine setup...too bad you're wasting all of its potential by going NA
Maybe one day you'll figure it out and come over to the dark side
Amen to that! haha the dark side.... Boost is where its at!
</TD></TR></TABLE>Amen to that! haha the dark side.... Boost is where its at!
N/A FTW
So it seems like everyone agrees this is a good setup. I've heard mixed reviews on blox cams though. What do you think?
I think this setup will make about 220 on a good tune. Sound about right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Razr2 »</TD></TR><TR><TD CLASS="quote">N/A FTW
thast what i thought too. i keep my cars all n/a and for your hp. i think only way to find out is get it on dyno machine. if it is already tuned, u dont need another dyno tune. just get it on dyno to find out the hp and torque and have it printed out on a data sheet. i think 3 pulls are like under $100
One of my friends just told me that this motor should be sleeved since it's running an 84mm bore? Is this true? I don't know much about motors to be honest.
I need this to be extremely reliable. Is it okay not being sleeved?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Razr2 »</TD></TR><TR><TD CLASS="quote">One of my friends just told me that this motor should be sleeved since it's running an 84mm bore? Is this true? I don't know much about motors to be honest.
I need this to be extremely reliable. Is it okay not being sleeved?</TD></TR></TABLE>
I don't think your set up is going to be 'extremely reliable.' Just my $0.2. Yes, Honda's are very reliable to begin with, but I think all of us can argue that modded Honda's aren't. (long-term) Sweet build though!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94delsol6428 »</TD></TR><TR><TD CLASS="quote">
It will be reliable as long as the owner built it correct. Everything is as reliable as you build it, skip out and buy cheap parts or dont replace parts during a rebuild and then it becomes unreliable.
</TD></TR></TABLE>It will be reliable as long as the owner built it correct. Everything is as reliable as you build it, skip out and buy cheap parts or dont replace parts during a rebuild and then it becomes unreliable.
The motor is already built.. It is in a car I MAY be purchasing. On the mod list it says who it was built by.
So it's okay not being sleeved?
Oh and if someone can tell me what this head code looks like to you that would be great. I cant decipher it, lol.
http://i262.photobucket.com/al...39276
Oh and if someone can tell me what this head code looks like to you that would be great. I cant decipher it, lol.</TD></TR></TABLE>
It looks like it says P73 (Integra Type R)
slick1851
Jul 8, 2010 08:27 AM
JdmK20aDC2
Feb 26, 2008 11:28 AM
