Help!!! How to remove ignition switch
take off the column cover, get a center punch, start tapping on the screws that hold the switch on... they wont have anything to grip on so you just need to gouge into it and tap it loose. then you can use needle nose or whatever
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by welfarepc »</TD></TR><TR><TD CLASS="quote">take off the column cover, get a center punch, start tapping on the screws that hold the switch on... they wont have anything to grip on so you just need to gouge into it and tap it loose. then you can use needle nose or whatever</TD></TR></TABLE>
wait what??
To remove the electrical part of the ignition switch, you need to take the plastic covering off the steering column, then find the metal ignition tumbler, and on the back of the ignition tumbler there is a white plastic peice with lots of wires going to it with 2 screws in it. remove the 2 screws and disconnect the wire harness and it comes out.
If you need to change the metal tumbler, then you are on your own because it sucks.
wait what??
here you go.... http://<a href="http://techauto.awar...witch.html</a>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc »</TD></TR><TR><TD CLASS="quote">my friend is stuck in the NYC
He needs to remove his ignition switch in his CRX how does he do it????</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=2223554
dgdarien
Oct 2, 2008 06:24 PM
