timeing belt
Old Feb 23, 2008 | 11:52 AM
leighton1245's Avatar
Default timeing belt
i have a z6 block witha y8 head and y8 cam gear and i cant get it to start could the timeing belt be to tight? cause it doesnt turn very easy?
Old Feb 23, 2008 | 12:06 PM
Default Re: timeing belt (leighton1245)
anyhelp plz?
Old Feb 23, 2008 | 01:00 PM
ddd4114's Avatar
If the timing belt is too tight, the car would still start.
An engine needs fuel, spark, compression, and timing to start. Have you confirmed any of these?
Also, if it's cranking slowly, check your battery's voltage.
Old Feb 23, 2008 | 01:09 PM
h-t_ruinedmylife's Avatar
Default Re: timeing belt (ddd4114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">If the timing belt is too tight, the car would still start.
Also, if it's cranking slowly, check your battery's voltage.</TD></TR></TABLE>
Old Feb 23, 2008 | 01:14 PM
i have checked compression fuel spark and mech timeing it trys to turn over but back firese thru the intake mani
Old Feb 23, 2008 | 02:00 PM
nub's Avatar
nub
recheck your firing order with number one cyl. @ tdc on the compression stroke 1-3-4-2
Jack Shephard
12
Feb 13, 2009 06:27 PM
civicmidwest_08
Jun 25, 2008 01:10 PM
roorensu
Oct 17, 2007 10:38 PM
G2integra217
Apr 8, 2005 07:27 PM
Civiclx
11
Nov 17, 2003 08:56 PM
