HELP cams...
What, you're trying to remove the cam gears but the whole cam rotates? You should have loosened the cam gear bolts when the cam caps were still on. You can also remove the cam gear bolt with an impact gun, just set it to the lowest setting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_ek9 »</TD></TR><TR><TD CLASS="quote">okay i was trying to takeout my cams off my camshaft</TD></TR></TABLE>
Cams=camshafts.
Cam gears?
Righty tightey/leftey loosey
Cams=camshafts.
Cam gears?
o aite....illl try it with my impact gun...im just scare to mess up anything...so i put everything back to its original spot...just that i didnt tigten the bolts i just put then back in screw then tight but not to tite...so yea...
216.226.142.95:27016
Jun 10, 2003 01:34 PM
