Del Sol Si vibrates over 60 mph
Old Feb 23, 2008 | 08:59 AM
xDelSolSiR's Avatar
Default Del Sol Si vibrates over 60 mph
I got my del sol roughly 2 weeks ago and have since then traded my 16' for some 17's.
would this cause my car to vibrate erratically when i got over 60 mph?
ive been told they need to be balanced but idk what that means.
Old Feb 23, 2008 | 09:03 AM
Targa250R's Avatar
be professional
Default Re: Del Sol Si vibrates over 60 mph (xDelSolSiR)
Sounds like they're out of balance. Go to a local wheel & tire service shop and ask them to re-balance your wheels. Simple as that.
Old Feb 23, 2008 | 09:06 AM
xDelSolSiR's Avatar
Default Re: Del Sol Si vibrates over 60 mph (Targa250R)
how much should i expect to spend?
Old Feb 23, 2008 | 09:15 AM
A lil 2.3l action's Avatar
anywhere around $10 - $25 a tire
Old Feb 23, 2008 | 09:24 AM
Blzdeep's Avatar
if the tires are new some shops will sell you a life time balance and rotate plan for like 25 bucks... well here in cali anyways, check it out. If you get the tires balanced, and the problem persists, have them break down the tires, and turn them 90 degres, the tires or rims could have a "true round" issue. If they have to put more then 2 or 3 ounces especially. But like i said rotating the tire 90 on the rim may help this.
Old Feb 23, 2008 | 09:43 AM
Default Re: (Blzdeep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blzdeep &raquo;</TD></TR><TR><TD CLASS="quote">if the tires are new some shops will sell you a life time balance and rotate plan for like 25 bucks... well here in cali anyways, check it out. If you get the tires balanced, and the problem persists, have them break down the tires, and turn them 90 degres, the tires or rims could have a "true round" issue. If they have to put more then 2 or 3 ounces especially. But like i said rotating the tire 90 on the rim may help this.</TD></TR></TABLE>
haha wow if you need to put 2-3 ounces on the rim then more than likely the rim is bent... if theres something rong with the tire or rim, rotating them 90 degrees would do absolutely nothing.. it would still be the same tire on the same rim
this is what you do.. if there new tires go back to the place that installed them for you and tell them your problem and they should fix it for free becasue they should have balanced the rim when they installed the tires... but its either 1 of 3 things, - your tires are out of balance - your rim/rims are bent - or your ball joints/suspension etc. are all screwed up, but that wouldnt be the problem because it didnt do this untill you put the new wheels on right?
Old Feb 23, 2008 | 10:14 AM
Blzdeep's Avatar
Default Re: (A lil 2.3l action)
i wasnt saying its a good thing
Old Feb 23, 2008 | 10:23 AM
Blzdeep's Avatar
but yo, spinning the tire on the rim does sometimes help, i worked with Discount tire Corporation for 6 years, and was certified by yokohama, micheline, and dunlop, it is part of the training they put you through, but whatever....
Old Feb 23, 2008 | 11:15 AM
xDelSolSiR's Avatar
Haha. Okay so I'm at walmart right now (thank god for internet on the phone. Ultimate boredom killer)
They charge 5$ per tire. The problem didn't start til I changed rims. So I'm hoping its just a balance problem. Thanks for all the help. I never knew that tires were so technical. Ill keep you all posted on it.
Now someone has to explain what all those numbers on the tire sidewall mean.
I'm alright when it comes to motors but god forbid I ever have to change/mount/balance a tire.
Old Feb 23, 2008 | 11:29 AM
Blzdeep's Avatar
Default Re: (xDelSolSiR)
what #'s , ya im just the opposite i know tires but crap about motors, i just know how to replace surface parts on the motors lol
Old Feb 23, 2008 | 11:30 AM
smileycvc's Avatar
The numbers are pretty easy. They determine the size of the tire. You usually have 3 sets of diffrent numbers they look like
xxx/xx/Rxx
So lets take 205/45/R16 for expample.
The 205 is the width of the tire in MM.
The 45 is the tire hight. However it is measure in percent. So the hight of this particular tire would be 45% of the width. Or 45% or 205mm.
The last number with the R in front of it is the rim size. So this tire would be for a 16 inch rim. The R actually stands for radial.
There are sometimes other letters such as p for passanger or maybe LT for light truck. Also tires have speed ratings. A diffrent letter is a diffrent top speed that the tire can sustain before it starts to lose reliability and can possibly explode.
Old Feb 23, 2008 | 11:31 AM
Blzdeep's Avatar
Default Re: (smileycvc)
alright those #'s lol dead on
Old Feb 23, 2008 | 01:12 PM
h-t_ruinedmylife's Avatar
if the balancing does not help you might need some hub centric rings for your rims..
Old Feb 23, 2008 | 01:47 PM
censurebush's Avatar
From: everything for everyone, and nothing for ourselves
Default Re: (h-t_ruinedmylife)
lol, off topic but i love this guys sn^^
Old Feb 23, 2008 | 01:57 PM
InfamousDelSol's Avatar
Default Re: (censurebush)
if its not the rim you bought it could be your tie rods... Happened to me, but you can check by jacking your car up and wobbling the tire left to right and up and down to check for tie rods or wheel bearings.
Old Feb 24, 2008 | 12:11 PM
Default Re: (InfamousDelSol)
just balance the wheels first
Old Mar 3, 2008 | 08:36 PM
Del Sol on Steroids's Avatar
out of balance or just needs to be torque correctly, happened to me
sol_cal
Sep 20, 2014 04:37 AM
xPRIMO
Mar 7, 2012 11:05 AM
Synbios
Mar 13, 2007 03:17 PM
Burke
Sep 8, 2005 12:54 PM
Family Man
Jan 10, 2005 08:52 PM
