inlet & exhaust valve stem seals same?
Old Feb 23, 2008 | 07:32 AM
civtic's Avatar
Default inlet & exhaust valve stem seals same?
are the inlet and exhaust valve stem seals the same on a B18C4 engine (B18C1)? i got a set and they all looked exactly the same, they're fitted now but i looked up my Haynes manual and apparently they should be colour coded? don't know if it's a different shaft diameter on the valves or what..
anyone know if they're the same?
Old Feb 23, 2008 | 09:01 AM
Targa250R's Avatar
be professional
Default Re: inlet & exhaust valve stem seals same? (civtic)
They are not color coded like journal bearings, but the parts catalog is showing different part numbers for intake vs. exhaust.
Intake:
12210-PZ1-003 SEAL A, VALVE STEM (ARAI) $1.42
12210-PZ1-004 SEAL A, VALVE STEM (NOK) $1.42
Exhaust:
12211-PZ1-003 SEAL B, VALVE STEM (ARAI) $1.42
12211-PZ1-004 SEAL B, VALVE STEM (NOK) $1.42
If they were exactly the same, they'd have the same part number.
Pick up a Helm factory service manual instead of the Haynes manual.
Old Feb 23, 2008 | 09:19 AM
civtic's Avatar
downloaded the Service Manual for my car from teh Honda website and it says the same. Intake seals have a white spring and Exhaust seals have a Black spring but i guess that's for original Honda parts. I got mine from the autoshop as my Honda dealer is a bit far away...
hmm, i'll see what happens when i run it.
lordbucanero
Sep 11, 2012 05:51 PM
jrnsr
Oct 12, 2011 10:02 PM
Silvertc
Apr 11, 2008 12:16 PM
zerovandez
Sep 28, 2006 08:52 PM
