sk2 pro series + front camber kit squeaking...
didn't get much help at all from suspension forum, so i though you guys can help me out here.
https://honda-tech.com/zerothread/2230463
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious »</TD></TR><TR><TD CLASS="quote">didn't get much help at all from suspension forum, so i though you guys can help me out here.
https://honda-tech.com/zerothread/2230463</TD></TR></TABLE>
Grease them up really good and if that's where the squeaking is coming from, then all will be well afterwards.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny Mac »</TD></TR><TR><TD CLASS="quote">
Grease them up really good and if that's where the squeaking is coming from, then all will be well afterwards.</TD></TR></TABLE>thats what i was asking...
what type of grease?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious »</TD></TR><TR><TD CLASS="quote">thats what i was asking...
what type of grease?</TD></TR></TABLE>
Energy Suspension makes a urethane friendly grease called "Formula 5 prelube" or you can use a white lithium grease that is urethane friendly. Super-Lube makes a nice teflon (PTFE) based synthetic lube that also works well. Or, a not as good solution is to use synthetic grease with or without moly (molybdenum disulfide MoS2) and this works well also, but over time typical grease will degrade the urethane.
Energy Suspension makes a urethane friendly grease called "Formula 5 prelube" or you can use a white lithium grease that is urethane friendly. Super-Lube makes a nice teflon (PTFE) based synthetic lube that also works well. Or, a not as good solution is to use synthetic grease with or without moly (molybdenum disulfide MoS2) and this works well also, but over time typical grease will degrade the urethane.</TD></TR></TABLE>thanks for the informative post. im greatly appreciated.
thanks to all for the replies.
-slow ej-
10
Jun 4, 2003 08:42 PM
