would a '93 DOHC VTEC fit in '91 EX Coupe?
i own a 1991 Honda Accord EX Coupe and was wondering if the 1993 DOCH VTEC would fit in it and what modifications would i have to make to have everything work. Also my car is an automatic but i want a manual what kind of work (and money) would it take to swap it out? thank you
I'm guessing you mean a prelude twin cam. Yes they will fit. I can't really remember what I had to do to mine other than motor mounts and the ecm... The tranny option needs: Trans, pedals, shift cables, shifter, master cylinder, fluid resivoir, fluid line and dampener. You have to bypass the neutral safety switch, or if you're good with wiring, install one on the clutch pedal, and you have to wire the ignition switch to get the key to release. All in all, its the best mod that you can do to your car in my opinion, short of a heart transplant and boost.
Wilka
10
Jan 13, 2012 04:19 AM
EJ8chu
Feb 17, 2007 10:51 PM
