please help swapped engine in 91 accord to a H22A
Old Feb 22, 2008 | 08:08 PM
sparky176's Avatar
Default please help swapped engine in 91 accord to a H22A
swapped engine and it started up. was running rough changed back to the f22a4 ecu. Still running rough. Put new exhaust on and now it will not run. Turns over gets fuel but no spark. Plugs were fouled so changed them out, also put in a new ignition contrl mod. in dist. When I went to get parts all the 92-96 prelude dist. had a 5th wire for an external coil, the one I have has only 4, with coil in the dstribu. The engine is a H22A from Japan from between 1992 to 1996. My harness from my car mathched up. The engine originally in the car was a F22A4 if that helps. I also have not hooked up the v-tech harness, but I have been told that it should not matter just to get the car running. Any help would be great.
havokz32
Jul 26, 2011 07:43 AM
1994lude
Nov 23, 2010 01:04 AM
pchee373
Apr 12, 2006 01:08 PM
WNYAccordLX
Mar 22, 2003 06:12 AM
rakeem13
Jun 29, 2002 01:10 PM
