y8 head
well all of the feet except on fit but it didnt work cause when i tried to start it it just tried to fire but wouldnt a b7 dizzy will work? and what make and model is that out of? thanks for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leighton1245 »</TD></TR><TR><TD CLASS="quote">well all of the feet except on fit but it didnt work cause when i tried to start it it just tried to fire but wouldnt a b7 dizzy will work?</TD></TR></TABLE>
I have no idea what you're talking about.... please take your time when you type your post so we can understand you.
A b7 distributor can be found on a 92-95 Civic DX/LX or a 93-95 Del Sol S.
I don't know if your timing will be off, but it should not prevent you from starting the car. You can double check you mechanical timing to see if you need another cam sprocket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hott95ej2 »</TD></TR><TR><TD CLASS="quote">the came gears are the same and dont make a difference unless you didnt set the timing right</TD></TR></TABLE>
The z6 and y7/y8 cam gears are offset by a half tooth.
SPOON_BeIgHtEeNsEe
May 1, 2008 12:46 PM
The Internet Tough Guy
Apr 17, 2006 12:01 PM
