what should I go with???
Old Feb 22, 2008 | 05:41 PM
CRX-1991's Avatar
Default what should I go with???
What is the best shockes and springs to use to lower a crx si an inch to an inch and a half, with stock si wheels. so much to choose from what do you suggest??
Old Feb 22, 2008 | 09:23 PM
jamison1486's Avatar
Default Re: what should I go with??? (CRX-1991)
i think tein make springs that are advertised to drop the car a certain amount of height
Old Feb 22, 2008 | 11:11 PM
x4thGenCafe's Avatar
OF THE KINGS
Default Re: what should I go with??? (jamison1486)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamison1486 &raquo;</TD></TR><TR><TD CLASS="quote">i think tein make springs that are advertised to drop the car a certain amount of height</TD></TR></TABLE>
i agree also.
its seriosuly all up to you man.
its up to what you want to spend and have . .
idk
im no help as usual
Old Feb 22, 2008 | 11:17 PM
oodie's Avatar
What are shockes?
Old Feb 23, 2008 | 06:11 AM
EFSedanMan's Avatar
in my opinion tokico illuminas with tein s tech springs.
Old Feb 23, 2008 | 07:06 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: what should I go with??? (EFSedanMan)
w0000 w000 bandwagon replies.
OP what do you have to spend, what do you do with the car?
Old Feb 23, 2008 | 11:17 AM
gator88's Avatar
Default Re: what should I go with??? (***$nyper)
im running eibach pro kit and koni yellows. about 1.5 inch drop or somewhere close to it. handles like a dream and not bouncy or anything. daily driver during the summer. i drive on potholed roads, never scrape. I measured 2 days ago changing my oil and i have 4.5 inches of ground clearance at front crossmember i believe is where i measured. If you want a little drop, Eibach is the way to go. not the cheapest but works damn well if you arent in a state that is all flat and can have dropped coilovers.
Old Feb 23, 2008 | 08:35 PM
CRX-1991's Avatar
Default Re: what should I go with??? (gator88)
gater88~how much those??
***$nyper~its a daily driver car
Old Feb 23, 2008 | 08:58 PM
f-it3's Avatar
i'm also in the same place, looking for a decent set-up, maybe this will help crx1991, http://www.tein.com/products/index.html
kelviiv
Suspension & Brakes
Feb 8, 2008 05:24 PM
ej_miguelito
Suspension & Brakes
12
Dec 27, 2007 03:49 PM
Morasso
Suspension & Brakes
Oct 29, 2007 05:33 PM
Turbocivic94
Oct 29, 2006 04:39 PM
kevo2k6
Suspension & Brakes
10
Jan 20, 2005 08:01 PM
