Engine Codes Need Help Identifying
Old Feb 22, 2008 | 05:26 PM
dirty sanchez82's Avatar
I finally fixed the timing belt tension problem. I added another tensioner. But now my check engine light comes on a few miles down the road. Got home checked it, 20 short blinks, short pause, 1 short blink, long pause. 20 short, pause, 1 short. I looked around for a while on the search here but must be retarded today and can't find the list to tell me what I'm throwing. Help or links to help would be appreciated.
Old Feb 22, 2008 | 07:08 PM
IP RACING's Avatar
In with your thread man me and you have the same damn codes and I cant figure it out for the life of me.
Old Feb 22, 2008 | 07:16 PM
WTF is going on here? How long has yours been like this, what happened to make you throw a code?
Old Feb 22, 2008 | 07:29 PM
welfarepc's Avatar
ELD and O2 sensor.
when in doubt.... FAQ IT
Old Feb 22, 2008 | 07:30 PM
zcmotor's Avatar
if not mistaken it should be your O2 sensor and Electric Load Detector the O2 sensor causes the check engine to come on when its bad or not pluged in good
Old Feb 22, 2008 | 07:46 PM
JRZ88DX's Avatar
https://honda-tech.com/zerothread/1710584
for all your ECU needs
GL with the cars
Old Feb 22, 2008 | 08:19 PM
IP RACING's Avatar
Default Re: F*** man! I can't fix this damn car (JRZ88DX)
Ive checked codes already and switched my o2 and under hood fuse box. disconnected my battery to clear the code came back the next day. sometimes it will come on in the first 10 miles soemtimes I can drive couple days without it going on.
Old Feb 22, 2008 | 08:47 PM
zcmotor's Avatar
did you disconnect the battery before installing the new O2 sensor or whatever you added new ?
Old Feb 22, 2008 | 08:56 PM
vtec93accord's Avatar
I also have a Code 1 on mine as well. O2 has been replaced with brand new OEM Honda sensor also and it still does it. It usually come on everyday but i havent had it come on in a couple days now that i think about it, knock on wood haha.
Old Feb 22, 2008 | 09:30 PM
Default Re: (vtec93accord)
electric load detector? First of all what is that, and how do I fix it?
Old Feb 22, 2008 | 10:32 PM
IP RACING's Avatar
Default Re: (dirty sanchez82)
its suppose to be the underdash fusebox or the underhood fusebox. yes reset my ecu before and after installing the new o2
Old Feb 26, 2008 | 09:36 PM
IP RACING's Avatar
Default Re: (IP RACING)
Any ideas on why the codes come back. what to check?
Old Feb 27, 2008 | 05:37 AM
zcmotor's Avatar
if you already replaced the new parts with old ones then remove the two fuses marked 15 on your fuse box. then disconnect the batter.
Mine used to do the same thing even with the new parts . and what i did i disconnected the battery then hooked off the ECU and reconnected back.
Whatislove
Honda Civic (2001 - 2005)
23
Oct 15, 2011 06:30 PM
jjenkins
Mar 6, 2010 08:37 PM
taterbug
Jan 1, 2009 04:01 AM
ZeroEric
Aug 10, 2002 04:36 AM
jonnybravo
Mar 22, 2002 06:39 PM
