wheres the dent go?
Old Feb 22, 2008 | 03:50 PM
90Rexx's Avatar
Default wheres the dent go?
Ok so im doing my LS swap in my crx and i nkow you need to dent the fenderwell to get the alt pulley to fit in right? so where do you dent the fender? I know its on the driver side blah blah blah but does someone have a pic or a good explanation as to exactly where the dent goes and how big it should be?
If you can, use the rectangular cutout under the shock tower as a reference point...
Old Feb 22, 2008 | 03:57 PM
x4thGenCafe's Avatar
OF THE KINGS
Default Re: wheres the dent go? (90Rexx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90Rexx &raquo;</TD></TR><TR><TD CLASS="quote">Ok so im doing my LS swap in my crx and i nkow you need to dent the fenderwell to get the alt pulley to fit in right? so where do you dent the fender? I know its on the driver side blah blah blah but does someone have a pic or a good explanation as to exactly where the dent goes and how big it should be?
If you can, use the rectangular cutout under the shock tower as a reference point...</TD></TR></TABLE>
yes
thats where your "dent" goes
Old Feb 23, 2008 | 12:25 PM
90Rexx's Avatar
yah i know thats the area. but is it directly below to the right to the left? im trying to avoid putting the motor in mroe then once.
Old Feb 23, 2008 | 01:06 PM
exist12's Avatar
http://hasport.com/tech/installs/EFB1.htm
check the hasport website, it is very helpful with swap info.
JUNKIE DUCKY
Mar 31, 2008 11:37 AM
juanchoenuncrx
Oct 17, 2007 09:16 AM
spintboy
Jan 18, 2007 12:11 PM
equalizir
Jun 23, 2003 10:09 AM
uszcrx
May 30, 2003 10:58 PM
