2nd O2-sensor before catatlytic converter?
Old Feb 22, 2008 | 02:11 PM
not-a-stang's Avatar
Default 2nd O2-sensor before catatlytic converter?
I thought that the 94-95 cars only had one O2 sensor, on the exhaust manifold. Yesterday, I saw it had another O2-sensor-looking thing right before the cat. It was on a small section of exhaust tubing, in between the header downpipe and the cat... can it be removed?
Thinking of doing a header install.
Old Feb 22, 2008 | 09:01 PM
jaccord95's Avatar
Default Re: 2nd O2-sensor before catatlytic converter? (not-a-stang)
just leave the one on that small piece of tubing and plug the other...u only need one i bought header set with downpipe and had 2 O2 sensor holes i had to plud.....just use some old 02 sensors and weld them up good or use jb weld
Old Feb 23, 2008 | 11:59 AM
steerh67's Avatar
Default Re: 2nd O2-sensor before catatlytic converter? (jaccord95)
there should not be anything in the piece, if i remember correctly, its just a piece of flex piping. have you actually gone under the car and visually inspected what you were looking at.
Old Feb 23, 2008 | 12:27 PM
Default Re: 2nd O2-sensor before catatlytic converter? (steerh67)
I was installing a test pipe (shhhhh!) when I noticed the section of tubing with a wire'd o2 sensor looking object sticking out of it... It looks like second o2 sensor to me.
BTW, the exhaust seems to really neck down right before the cat. I wonder if a header replaces this piece also, or do I have to keep it so the header down-pipe can reach the cat/rest of the exhaust system.
iwannarace
Engine Management and Tuning
Jun 29, 2011 05:05 PM
urquidezj
May 25, 2007 01:25 PM
hinds90
Apr 25, 2007 05:41 PM
Benhawk
Mar 18, 2007 04:42 PM
WIb16crxWI
May 18, 2006 07:18 PM
